My 2018 Sierra 6.2 exhaust and other mods
Old May 26, 2021 | 07:19 PM
  #111
FabAddict's Avatar
All you got to do is ask. It has been done!
thank you!
This weekend is the date. Going to disassemble and start phase 2. But I could use some options.
-should I remove the rear spring mounts from the frame? They wont be used or will they be in the way. I will be cutting the spring mounts off the axle, so going back would be difficult anyways...
-is it just me or do you guys think the frame coating sucks? Any recommendations on something better i can at least hit with the cab back?
Old May 27, 2021 | 12:58 PM
  #112
Jeebalow's Avatar
If you're cutting the mounts off the axle, might as well cut them off the frame as well. Will look much cleaner.
Can't wait to see it all together.
Old May 27, 2021 | 01:37 PM
  #113
tjmath's Avatar
Originally Posted by FabAddict
thank you!
I have seen a couple trucks out here get the whole undercarriage sprayed with line-x. Obviously that's gonna make it a pain in the *** to do any additional mods and really more for a finished product but it looks damn good and holds up really well.
Old May 27, 2021 | 01:49 PM
  #114
shakenfake's Avatar
Shlumpt
5 Year Member
Frame coating is good but from what I have heard you should not hit it with Line-X
Old May 27, 2021 | 03:34 PM
  #115
tjmath's Avatar
Curious where you've heard that, as well as why. Like I said, I have seen it done on a couple of different trucks.
Old May 27, 2021 | 03:40 PM
  #116
shakenfake's Avatar
Shlumpt
5 Year Member
If Line-x chips at all you are screwed when water gets in and rusts it from the inside out. That won’t realistically happen but I’d rather see a frame get painted and make sure that everything is all good every now and then.
If you Line-X it then you are also making any future repairs etc more difficult because you now have a thick layer of tar basically over all the bolts and metal so no more welding.
Just my opinion
Old May 28, 2021 | 11:55 PM
  #117
FabAddict's Avatar
Line X sounded great but Snake has a good point...
Made some progress tonight, little teaser.
Old May 29, 2021 | 01:09 AM
  #118
1FastBrick's Avatar
Custm2500's Rude Friend
Use an Epoxy paint. Being in California I don't think you will have any issues. Just make sure you get as much coverage as you can in all the hard to reach area's.
Old May 29, 2021 | 06:36 PM
  #119
FabAddict's Avatar
True! We use epoxy paint on our farm equipment and it seems to hold up.
Got started a little later than I wanted🤦‍♂️
working on panhard bar mount
Old May 29, 2021 | 10:27 PM
  #120
FabAddict's Avatar
Running out of light!
axle mounts welded, panhard mounted, 4 link tight. Now its upper bag mounts and double check everything.
