LVL 4 FLT 80e Swap into an '04 SSS
#71
I got the FLT level 4 trans, so whatever that comes with is what I have in it now.
Here's a link
Finish Line Transmissions | Performance Transmissions | Torque Converters | Transmission Parts | Transmission Service
Here's a link
This I'd really like to see!! Too bad we're gonna wait so damn long for it.
#74
Yes, both Chris and Chuck knew about the Jackshaft and each knew about the whole build I was planning - I'm surprised Chuck didn't recommend the shaft. He was trying to sell me on their lvl 7 65e instead of the 80 though...I obviously decided against that.
#76
Well to start off, I'll only be installing the pulley that comes with it since I don't have the engine mods yet. I'm guessing it'll be 6 - 8 psi or so. Then I'll be buying rims and Speedsturr cover THEN will come the cam, rods, springs, ported heads, etc. After I have all the supporting mods done later this Summer or Fall is when I'll pulley down to somewhere around 15 psi and probably be looking at 20 before everything's said and done. That's why I'm opting to spend the extra money on the Jackshaft so as I get used to the power, I can just pulley down and add more...MOOOHOOO HAHA HAAAAAAAAAAAA!
oh yeah, there's a cog drive available for that blower that I'll be adding too...should sound pretty sick
#77
Ya the cog setups sound cool for awhile but to me it would get annoying after a bit. You should not have a issue getting the blower to hit those levels, I should be able to get 19 out of mine if I ran a 2.7 drive pulley.
For those levels plan a whole new fuel system, Meth, better rear driveshaft and plan for the rear end to give out.
#78
#79
Not sure what pump comes with the kit, and for reference boost is not a accurate measure of power. Cam plays a large role in fuel demand also, as I pointed out with your cam your fuel demand stops climbing after 5500. A larger cam is going to keep raising your fuel demand as RPM climbs. Not sure what injectors come with the kit either. I would think you should be good for 8-10psi as the kit comes fuel wise.
