LVL 4 FLT 80e Swap into an '04 SSS
Old Apr 24, 2014 | 09:59 AM
  #191
03sierraslt's Avatar
You cannot go off of current gear as when the shift has happened, you have to look at engine RPM. Your RPM settles at 4:41.357 and around a second later you are at 48mph. The current gear that you are looking at is when the trans actually commanded the shift. The 80E does not shift as fast from command to shift completion as a 65E as all the parts are heavier. Based off of math you are not getting slip in those frames. Regardless of what the converter is doing, if you know the current gear and the input and output speed on the trans you can calculate to find slip if in 1-3 gear.
Old Apr 25, 2014 | 12:03 AM
  #192
L8ERBRO's Avatar
So is this "normal" then? I really wish someone could take a test drive with me because I find it very hard to believe everything is functioning as it should during that downshift/acceleration.
Old Apr 27, 2014 | 11:56 AM
  #193
FLT's Avatar
FLT
FormerVendor
Originally Posted by L8ERBRO
The trans. seems to be just fine except for the soft shifting. I was just wanting your opinion to adjust the shift pressure to make 1-2 and 2-3 a bit firmer - is this okay to do the way you've built this trans.? I know we discussed the Transgo Kit during the ordering process and you told me you didn't use them anymore.
My only concern is the downshift into 1st from a 40 roll - there is without a doubt an "issue" there and I'm hoping it's the converter loading up like Rob said in that earlier post.
You can increase the shift pressure if necessary, I would make conservative steps though until you like the shift feel? Far as your downshift from a 40 roll, you need to remember that your 1st gear ratio has been reduced by just under 24% with the 80 swap. This is why so many guys complain about their trucks feeling like a pooch out of the hole after the 80 swap. Now throw a looser converter into the mix and you just multiplied the issue. Until you have the t/q to get you through that rpm range, you'll have to deal with your current 40 roll downshift to 1st gear complaint.
Old Apr 27, 2014 | 01:36 PM
  #194
L8ERBRO's Avatar
I have no problem dealing with this issue until the boost. I was just worried there was a problem somewhere and didn't want to compound the issue with extra horsepower. Thanks Chuck!
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
bighouse
Sep 27, 2015 12:37 AM
05GMC4.8
Aug 7, 2015 09:55 PM
iregret
Jul 27, 2015 10:32 PM
JordanH
Jul 14, 2015 03:46 PM
