Lets Try This Again: 410-PT88-80e
Old Jan 10, 2011 | 02:58 PM
  #331
Swerve7rpm2000's Avatar
Hey atomic did u have the ring landings moved down any on these pistons? Just curious sorry to hear and see the bad news, good to see u not getting beat up over it, seems like alot of people have your back
Old Jan 10, 2011 | 02:59 PM
  #332
Atomic's Avatar
I have a gauge for that
I dont know, the log never went lean. Maybe the injector got stuck closed or something.
I had LME do the shortblock work and assembly. Giving them a call shortly.
Old Jan 10, 2011 | 03:02 PM
  #333
Daryn's Avatar
Formerly darynC-10/23/10
how many hours of runtime do you think you have on this motor?
Old Jan 10, 2011 | 03:07 PM
  #334
Atomic's Avatar
Not many, maybe 15. Less than 600 miles on it.
Old Jan 10, 2011 | 03:10 PM
  #335
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Is that a broken ring or is that where the gap in the ring is at?
Old Jan 10, 2011 | 05:09 PM
  #336
Spoolin's Avatar
GFYS and STFU
Ouch!! Check the turbine, I'm hoping that the debris got ingested by the engine but I don't think it's possible with that amount of damage.
Where is your AFR sensor located?
Old Jan 10, 2011 | 05:16 PM
  #337
Atomic's Avatar
Dunno, may be where the gap is.
Wideband is right after the turbine in the downpipe. The turbine looks fine as far as I can tell, just oily.
Old Jan 10, 2011 | 06:05 PM
  #338
black04's Avatar
Shouldn't have put the fire out
Kidding. Hopefully LME has you covered
Old Jan 10, 2011 | 07:14 PM
  #339
custm2500's Avatar
Ph.D. in HUBRIS
WOW!
Is the cylinder wall OK? I would guess it got scratched but I sure hope not! I can't imagine the walls taking any more honing.
Old Jan 10, 2011 | 07:23 PM
  #340
1slow01Z71's Avatar
Reason I ask, if that is where the ring gap was at, its clocked wrong and also wasnt running the right gap for your intended use IE builder error. If its just where the ringland gave up and in turn toasted the ring then obviously its on you whether it be tuning or overboosting it.
