Lets Try This Again: 410-PT88-80e
#213
It is amazing how event a small exhaust leak can effect turbo spool. On my stock 6.0 Powerstroke in my work truck a fairly small leak made a noticable differance. Obviously they turbo needs some pressure infront of the turbine.
#214
#215
They are professional products fuel rails. Anything will work with enough effort. I had to space these and grind a little on the mounts for these to work.
#216
Ugh, just broke something. Was playing around, hear some loud clanging, thinking oh **** a rod or something...nope, oil pressure is fine...drove home about 2 miles. Parked in the driveway, couldnt find anything, all fluids look fine. Start the engine, sounds fine, put it in gear...nothing...just rolls in every gear but park
so it looks like the transmission
#218
fuuuuuuu 1000hp my ***. im waiting for the exhaust to cool off so I can drop the crossover and inspection cover. im hoping its just something stupid like the torque converter bolts or flexplate
#219
Check and see if your fluid level drops when put in drive, may have chipped the pump when isntalling the converter. On my first trans swap ever, I cracked the pump and put a couple hundred miles on it before it crapped out.
