Jake's '05 Rcsb s488 4l80 build
#211
Not sure if the HVAC module needs to see the engine run flag as true on serial data in order to operate, or at least the BCM needs to see this as the Power Mode Master in order to tell the HVAC module to transition from Awake to Run mode.
#212
Just curious because I believe the 2002 PCM uses a 12V AC request signal from the HVAC module. The 2005 HVAC module uses serial data for the request.
Got the oil gauge hooked up I have a good 40 psi at idle. Took off the valve covers and some of my rockets have side to side play. But they are tight torque wise. My push rods are 7.4 but I ordered a length checker just to be safe.
#213
#214
I'm still kinda confused on what I'm going to have to do to the wiring to make the ac work.
#216
Rockers having some side to side looseness to them when the valve is closed and lifter is on the base of the lobe is actually somewhat normal, unless its just a ridiculous amount of movement then theres an issue.... Ive had brand new gm lifters that were soaked before installing take a few seconds to pump up properly..
#217
#218
Yeah it be should at this point! If you take both valve covers off and start it it should be fairly ovbious which lifter it is... Probably want someone else to crank it, and shut it off... Just as a side note i have an exhaust leak that had me chase a lifter knock for a few minutes until i realized it was a leak at the manifold flange...
#219
