Jake's '05 Rcsb s488 4l80 build
#203
Just to back up a little bit about staging. The way I always did it was to light the first light, get on the brake and bring the boost up to 1-2psi. Not enough to make things get hot but just enough to get the turbo speed somewhat high since boost is exponential with the speed. Going from 0-2psi might take 3 seconds, but 2-12psi might be 1 second, for example. I would wait for the other guy to light both beams then I would get on the 2 step and roll into the second beam. Easier on the foot brake but you can use a bump box with a trans brake to do the same thing without having to worry about burning down. Footbrake should be able to hold 1-2psi even on a 2wd truck.
#204
Went today to get a oil pressure gauge and none at the auto zone/oriellys would have worked needed the adapter. So i ordered the adapter and a gauge off amazon.
In the mean time i put the plugs/wires in and slapped together the wiring (looks shitty right now once it fires ill take it off and route it the best i can)
Also i figured out what my problem was with hptuners...I got a new pcm and tried to write entire. same error came up (Negative response). For some reason i decided to hook up jumper cables from my daily to the truck and try the tune write again...that did it! I guess the battery was too low and it was causing some type of error before it would even start writing the file.
#205
Got it cranked today motor has a top end knock gotta pull the valve covers tomorrow. Hopefully it's just because the lifters were dry.
http://s20.photobucket.com/user/jpre...023_1.mp4.html
#207
also it looks like all the stock body functions work with the engine on its own harness and the bcm connected to the fuse box
#209
