Jake's '05 Rcsb s488 4l80 build
Old Sep 20, 2016 | 10:05 PM
  #181
Jake75's Avatar
Originally Posted by Wolftrk99
I personally would like a tad taller tire, but again just my 2¢!!! Looks good!!
yea i might end up changing them...they were just some throw down tires so i had em put on.
Old Sep 20, 2016 | 10:06 PM
  #182
Wolftrk99's Avatar
Hey, if it gets you rolling!!
Old Sep 21, 2016 | 01:28 AM
  #183
Blown06's Avatar
8 Second Truck Club
Just remember, the taller the front tire, the better the et at the strip!
Old Sep 23, 2016 | 03:43 PM
  #184
Jake75's Avatar
Being that I'm using a 02 harness on a 05 truck do I need a 02 fuse box since the pinout are not the same on 05 the connectors to the fuse box?
Old Sep 23, 2016 | 03:46 PM
  #185
1FastBrick's Avatar
Custm2500's Rude Friend
Why are you using an 02 harnes???
Old Sep 23, 2016 | 04:12 PM
  #186
Jake75's Avatar
99-02 that's what I was told I needed since it's a dbc truck originally
Old Sep 24, 2016 | 02:12 AM
  #187
Blown06's Avatar
8 Second Truck Club
Have you considered just converting it over to a standalone harness and being rid of all the extra bullshit?
Only thing I don't know is if you are still trying to use bcm functions that may not be an option.
When I think of your truck I put it into a category closer to mine than a normal street truck. That said, you could convert the harness over to a stand alone to make that all very simple and modular. Then wire the rest of the truck old school style and be rid of all the bull **** you don't need. You can still have your power windows, locks, lights, blinkers, horn and all that ****....you'd just do it on it's own circuit board. Thats how mine is done. I only retained power windows, lights (drl's, park, low beam, high beam, fog, license plate and brake lights). I did not add a circuit for the blinkers. I kept the speakers in the truck in the event that one day I want to put it back on the street......and I'll just use an aftermarket head unit.
Old Sep 24, 2016 | 08:38 AM
  #188
Jake75's Avatar
Hadn't thought about it but if I can't get it working with a new fuse box that will be my next option. I want to be able to have a complete working truck with the gauge cluster, lights and ac. The truck has manual windows with power locks.
How did you go about getting everything on a different circuit? I wouldn't even know own where to start with that
Old Sep 24, 2016 | 12:52 PM
  #189
1FastBrick's Avatar
Either Re-Pin a later 03-up harness or use one from an 03-up Van as they were DBC.
The 99-02 will not communicate properly. You might also be able to repin that as well to work with the 03- up computer.
Old Sep 25, 2016 | 02:39 AM
  #190
Blown06's Avatar
8 Second Truck Club
I stripped every single wire out of my truck and started fresh. Made my own fuse/relay panels, added all the necessary switches and wired the whole thing myself. I have about $2000 in wire crimping tools a miles of different colored/gauged txl wire that I used. It was a major undertaking in the beginning as just starting to think about can make your head spin. I also forgot to mention, I ran my fuel pumps, water pump, intercooler pump, transbrake and rad fan as part of the custom truck harness (those items where kept separate from the engine management system). First thing I did was buy an inductive tool to measure the load draw (amps) of each component and sized the circuit accordingly. It was a lot of work, but turned out really nice in the end and every thing worked flawlessly.
To get around the gauge issue, I first gutted a stock cluster and installed all the necessary autometer gauges, then in the end decided that I didn't need all that jazz as it was being data logged anyway. So I just put 3 gauges up on the pillar (fuel press, oil press, afr) and mounted a tack w/shift like in the factory cluster.
If you would like to do something similar, let me know and I'll quote you a price.
This is the harness to the rear
Door harness's for the windows and speakers
Harness to the front for the lights
Main switch panel:
Switch panel for the lights
Front and Rear harness coming through the firewall
Not a good shot, but the main panel
I've probably got more but you get the idea.
