ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
#242
Thanks guys. I found the perfect spot for the coils and I don't have to extend the harness, so I'll work on that this evening. Once they are mounted and plugged in, I will finish looming that small harness and the wire tuck will officially be done.
The upper radiator hose techflex finally came in (1.25") and so I was able to finish all the cooling system.
#243
This is where I decided to mount the coil. First few were the test fit and once I knew they worked and the spark plug wires could be installed, I removed the crossmember and mounted them nice and level
Was not expecting this orientation of the wiring, so I think it's easier to just cut the ends off and make a new harness
I also ordered a build your own spark plug kit, some DEI sleeving for them, and some other odds and ends.
#247
- Build spark plug wires
- Route BOV vacuum line and MAF wiring
- Figure out gauge sensor locations and get the wires over to them
- Bleed front brakes
- Swap upper control arms or swap bushings with OEM since the Belltech have too much camber right now
- Install passenger side coilover
- Fill cooling system and burp it
