ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
#141
Yes, that would work. I went a little further and used tubular lower control arms so I could use a longer shock and hopefully ride better. So I didn't use Atomic except to purchase the shocks and springs, but wouldn't hesitate to purchase his brackets for your truck
#144
That's correct, I didn't have a way to put 230lbs in the drivers seat, but the weight of the truck is still on the rear axle since it's up in the air and jackstands are under the axle. I have the truck up in the air so you can see the front suspension a lot better now if you want to drop by some point on Sunday to check it out.
#145
Have you gotten a chance to drive it yet with the coilover conversion? I've been unsatisfied with both of my nbs trucks' ride quality, so this might be a good solution. My Vikings on my 4th gen Camaro rode great.
#146
Not too much, only like 50 miles, and I was more worried about the fresh build and listening for noises instead of focusing on ride quality. I will say the Viking setup on my gray extended cab rode wonderfully, even in Austin shitty roads.
#147
