ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Mar 31, 2018 | 04:38 PM
  #181
408gto's Avatar
That's going look great and be super clean and I love all the pictures
Old Mar 31, 2018 | 04:48 PM
  #182
ILuvJDM's Avatar
Thanks guys
Originally Posted by smokeshow
I think I would have to be on cocaine to put this much energy into cleaning the engine bay or taking this many pictures.
Alcohol gives me the courage and gets me started, cocaine keeps me going through completion
Old Apr 1, 2018 | 12:17 PM
  #183
terravast4's Avatar
atta boy!!!
Old Apr 3, 2018 | 08:25 AM
  #184
Fabsmith828's Avatar
Originally Posted by ILuvJDM
I've got VAS traction bars.
I was looking at the truck and trying to decide what the previous owner might have done to it. Check these out and let me know what you think it could be from?
Odd hole drilled in rear fender looking towards front of truck in picture
This hole looks like a Paintless Dent Repair hole. Not sure why they would need one in that location unless this just happened to be the best spot for leverage?. I could be wrong but i used to work for a few dealerships and when they picked vehicles up from the auction or trade in, they would have a pdr guy go over them. Some dealers offer the work to customers through the shop. If they couldnt access the dent very well, they drill a hole in an inconspicuous spot. However they usually smear it with paint or a sealer then stick a plug in it to prevent corrosion or moisture getting in. Youll see them a lot in the sides of doors when you open them on car lots. Theres lots of vids of how its done on youtube if you arent familiar. Like i said though, i could be wrong but it gets my vote.
Also i love this build, its turning into a very impressive truck! I have an 02 silverado rcsb with a 6.0 swap. This thread has provided some much needed inspiration for sure. Ive got a set of 799 heads ive got to put on mine but ive been lazy about buying my supporting bits it needs.
Old Apr 4, 2018 | 07:30 PM
  #185
ILuvJDM's Avatar
I'm looking for input on where I should mount my coils. I tried putting these thinga all around the truck and here are the three options I found:
On firewall, it is just hung on an existing Bolt, it would obviously be straight and probably lower. I would have to extend my drivers harness for sure
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-kovu4g7.jpg
With stock intake manifold
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ztwloka.jpg
Option 2:
Down under the oil pan. I would probably build a small aluminum shield for rocks and stuff. I can also get this one a bit higher by just using the bottom bolt holes and having it above that lip.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-y3ykkqe.jpg
Option 3:
Down low again, but vertical so there is less exposure to road debris. Would still make a plate to protect it.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ebo0xwr.jpg
Old Apr 4, 2018 | 09:14 PM
  #186
408gto's Avatar
Think about how long the plug wires will be
Old Apr 5, 2018 | 12:14 AM
  #187
01FormulaTA's Avatar
Whats wrong with mounting them on the valve covers?
Old Apr 5, 2018 | 06:25 AM
  #188
ILuvJDM's Avatar
no mounting bosses for coils, plus that's the point of doing a wire tuck.... Plenty of very high horsepower cars and trucks have coils in their cowls or even fenders. Plug wire length is not a concern at any of these locations
Old Apr 5, 2018 | 08:06 AM
  #189
Jeebalow's Avatar
I like them down low horizontal. I'm assuming you won't be driving it in the rain much.
Old Apr 5, 2018 | 08:12 AM
  #190
Atomic's Avatar
I have a gauge for that
My plug wires ended up being about 36".
Most aftermarket 8mm wire is 150ohms/ft at worst. The stock wires are like 900ohms/ft. So a 6ft generic aftermarket wire is about equal to a stock wire.
