ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Mar 27, 2018 | 07:12 PM
  #161
ILuvJDM's Avatar
This was at my door today
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-uq2ktj0.jpg
Got one side installed
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ymqk75q.jpg
Old Mar 27, 2018 | 09:47 PM
  #162
thunderwagen's Avatar
How much more clearance did you gain with the ridetech arms over the VAS arms?
Old Mar 27, 2018 | 10:32 PM
  #163
Atomic's Avatar
I have a gauge for that
I didnt realize you were changing up LCAs...how come?
Old Mar 28, 2018 | 06:18 AM
  #164
ILuvJDM's Avatar
It wasn't done to gain clearance, I just didn't like the lack of swaybar and some other quality control issues. Turns out ridetech has some of the same issues. Didn't get zerk fittings in the parts bag, chipped powdercoat, I think I just have bad luck, or nobody gives a **** about quality control anymore
edit: just spoke to technical support and these arms have Delrin bushings now, so grease zerks are not needed. So really the only defect was one small chip in the powdercoat, which I can live with for sure.
Old Mar 28, 2018 | 10:23 AM
  #165
SDjeff619's Avatar
Did you use oem or aftermarket rear fender liners?
Old Mar 28, 2018 | 10:33 AM
  #166
Reckless's Avatar
Still moddin'
I deal with this constantly because I handle all the parts shipments at Vengeance. It is more prevalent than it should be, and it is not just one company. People just don't have pride in their work anymore. It was probably poor packaging and gorilla handling by the carrier.
I see such poor packaging by some of the vendors it is unthinkable how much they much lose from returns and shipping costs.
Old Mar 28, 2018 | 11:46 AM
  #167
ILuvJDM's Avatar
In the case of the ridetech arms, it had more packaging material than I have ever seen in my life. Very well packed, but the defect was by the balljoint, so I'm assuming it happened during assembly and just didn't get resolved. It's not enough to make me send them back, but still annoying. I came from the import world, specifically Evos, and companies like ETS, STM, AMS, etc... You ordered a part and it looked better than the pictures when it arrived
These are rugged liner brand, WC99 I believe is the number. I get them from Amazon for $90.00
Old Mar 28, 2018 | 06:14 PM
  #168
408gto's Avatar
I just bought a set of djm upper and lower control arms for my obs build and one of the lower ones has a 2" section at the ball joint that the powder coating is chipped only good thing is I don't like the color so iam going to powdercoat them myself
Old Mar 28, 2018 | 08:28 PM
  #169
ILuvJDM's Avatar
Since I had a new ACDelco master cylinder on my parts shelf, I figured I would put it on
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-3skzxu7.jpg
Any bets on if that was the original fluid from 2007?
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-dg3fupi.jpg
Bench bleeding new one. Is it normal for the plunger to only go in like 1/8"? The instructions said 3/4"-1" but I put all 235lbs into it and it wouldnt go any further... Bubbles came out for a while and eventually it was perfect fluid with no bubbles, so I'm sure it's fine
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-57j1rzm.jpg
Installed
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-da0l0ep.jpg
Front suspension is done, just need to bleed the brakes and do an alignment then bolt up the coilovers. Good news is the measurement for ride height only went from 11.75" to 12.0" at my ride height, so the c205 shocks will still work perfect
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-6pss6dt.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-yshngcy.jpg
Old Mar 29, 2018 | 10:25 AM
  #170
JeffT's Avatar
Nice project and build!
