I hope I'm not late for work!
Old Mar 2, 2015 | 12:30 PM
  #701
Vortec350ss's Avatar
Good stuff! I wouldn't screw with the trans tune too much... you may find that you dont need to downshift much with the blower either.
Old Mar 2, 2015 | 12:37 PM
  #702
Recheck the tcc valve...pretty easy to put in upside down.
Old Mar 2, 2015 | 01:05 PM
  #703
Atomic's Avatar
I have a gauge for that
Well my issue is it worked fine for a while (couple weeks). Then I could feel the apply getting softer and softer, and now it doesnt even try.
Old Mar 3, 2015 | 09:25 PM
  #704
ChevyThunder17's Avatar
Originally Posted by Atomic
Well I actually drove it around on Sunday.
You are much farther along than I am.
The system is sitting on the shelf because my daily driver (VW CC) ate the turbo on it. I'm almost certain that I'm getting "compressor/turbine wheel on their respective housing" ringing. Now I have to probably swap connecting rods in and get that going again before I can drag the Escalade in and give it some much needed boost. It's hard going back to NA after forced induction.
Sounds like you are enjoying it.
Old Mar 4, 2015 | 06:59 AM
  #705
Atomic's Avatar
My NA tune sucks compared to how it drove with the turbo. The good news is you really have to screw something up to wreck a low compression forged NA engine built for boost.
Old Mar 7, 2015 | 02:06 PM
  #706
DV2000NJ's Avatar
13 Second Truck Club
Definitely interested in what you do with the new setup!
Did you ever get that 5.99 pass?
Old Mar 7, 2015 | 02:58 PM
  #707
Atomic's Avatar
I got 6.05 before I broke the input shaft. I know it had a 5.99 in it, but I just didnt get the timeslip to prove it. Didnt get a whole lot of time to dial in the slicks either.
I started the truck today, but the radiator appears to be screwed since it was dumping coolant on the ground. Best I can tell its coming out between the core and the end tank. Always something.
Old Mar 7, 2015 | 05:01 PM
  #708
Especially with a blower. No over-boosting.
Old Mar 10, 2015 | 11:07 AM
  #709
What heads do you run on this beast?
Old Mar 10, 2015 | 12:07 PM
  #710
Atomic's Avatar
WCCH stage 2 L92s. They been shaved a lot, and have LY6 inconel exhaust valves. Theyve been beat on quite a bit. Melted one chamber and had it welded up, and its been fine since.
