Well got the trans fixed and back together. Replace the whole OD piston pressure plate thing as well as the sprag. That thing is tricky to install correctly. I deleted the 2-3 and 3-4 accumulator as well while I was in there. Still not sure I did the checkballs right but it shifts so thats all I care about. Took it for a test drive around the block and wow this exhaust is loud
Got a bath too:
Ready to party once the tracks open back up here
These turbos spool really fast which I think a lot of it is the downpipes, but at low speed and less than half throttle I am at 6psi+ in less than a second from the turbos (so 15psi+ total).
Second thing is the intercooler pump is a beast. I set it up so I can hook an outlet hose to the return fitting in the tank to drain it just by turning the pump on and it literally drained half the cooler (about 5 gallons) in about 10 seconds before I could walk around the truck. Its definitely moving some volume. I dont think there will be any advantage to running more than 50% honestly, the water temperature got up to the intercooler temperature very quickly, so the pump is doing its job. Now I just need to make sure I have plenty of ice on hand because it took 11-12gallons to 100F water in a couple of minutes of easy driving.
