I hope I'm not late for work!
Old Apr 26, 2017 | 07:09 PM
  #1761
MikeGyver's Avatar
I had Gates hose fail twice. I heated the flexible plastic hose by holding the end in hot oil on the stove to get it hot enough to soften., because boiling water wasn't hot enough. There's a narrow temperature range between softening and melting, so have a spare hose if anybody is going to try it. Sorry I don't remember, I think it was 300 degrees. I was determined to make it fit after having two failures with the Gates hose.
Old Apr 26, 2017 | 08:39 PM
  #1762
03sierraslt's Avatar
I did that too with the white hose and a heat gun. It was a motherfuc@&r. Your right, there is a narrow window where it goes from pliable to melting.
Old Apr 27, 2017 | 09:37 AM
  #1763
Vortec350ss's Avatar
Yea and finding that range with a lighter sucked ***... I went through more than one spare, I'll leave it at that.
Old Apr 27, 2017 | 09:46 AM
  #1764
Atomic's Avatar
I have a gauge for that
Yea considering the gates hose right next to the failed one is perfectly fine I am just going to replace the failed one with the gates that should be here today. I am thinking the installed height was off so when it was installed the second hose was stretched instead of relaxed so I am going to be more careful about installed height to make sure its relaxed when installed.
Old Apr 27, 2017 | 05:53 PM
  #1765
Petraszewsky's Avatar
Use some flexible "straw" hose like OEM and oetiker clamps it won't burst/split like that rubber hose.
Old Apr 27, 2017 | 06:44 PM
  #1766
GMCtrk's Avatar
If you order nylon hose, buy backups as they can be a bitch to get on.
Old Apr 27, 2017 | 08:05 PM
  #1767
Thanks for joining in....... Lol
Old Apr 28, 2017 | 10:19 AM
  #1768
kbracing96's Avatar
What about using those plastic flexy hose things?
Old Apr 28, 2017 | 11:54 AM
  #1769
Atomic's Avatar
You people
Got it fixed last night and made sure to compress it to the installed height first, ended up only needing a 2.5" section of hose to fix it. Straight shot from the pump to the barb. Its also funny just how big this bucket is. Tons of room in there for fluid to keep the pumps submerged. No external holes except for the flapper valves at the bottom. My setup is a bit bastardized, its an 05 bottom bucket with an 07 top in an 07 tank.
Installed and tested both pumps and everything is good now. Also got the reference line to the cutout ran to a vacuum block off the lower manifold.
Old Apr 28, 2017 | 01:58 PM
  #1770
silver-mod-o's Avatar
Hunt&Fisherator
No way to put a loop in that hose? Probably what I would have tried. Would have given you some room to play with.
