I hope I'm not late for work!
Old Apr 12, 2016 | 02:57 PM
  #1441
Vortec350ss's Avatar
Pat thinks itll explode, eh?
Old Apr 12, 2016 | 03:11 PM
  #1442
Atomic's Avatar
I have a gauge for that
Guess we will find out!
Old Apr 12, 2016 | 04:12 PM
  #1443
Niiice!
From what I have heard the 2.3 is much better with over spinning than the 2.9 is. I think you'll be fine.
Christ look at what CTS guys do with the LSA blower. Eaton recommends 18k max as far as I know and those guys hit 21k.
Old Apr 17, 2016 | 07:58 PM
  #1444
Atomic's Avatar
Got a chance to take the blower off and test fit the spray bar setup. Only ran into 1 snag with the tube hitting part of the intercooler but a little dremel work and all is good now. Replacing the fuel rail screws with some flat hex head ones makes more than enough clearance.
In the top part,
You can see the screws I was talking about here (bottom half),
I have some oil in the bottom of the lower manifold when I took the blower off, kind of pooled near the back. I am not sure where its coming from as my PCV vents to atmosphere and it cant come from anywhere else, so not really sure about that.
Old Apr 17, 2016 | 08:26 PM
  #1445
BlackGMC's Avatar
Resident Retard
Looking good man!
Old Apr 18, 2016 | 10:00 AM
  #1446
Looks good. Is it definitely oil from your engine? Or is it from the previous owner? Did you have it apart and clean before putting it on?
Old Apr 18, 2016 | 10:58 AM
  #1447
kbracing96's Avatar
Probably entrapped in the intercooler from it's previous life would be my guess.
Old Apr 18, 2016 | 12:01 PM
  #1448
Atomic's Avatar
Not sure if its from mine or not...I thought I hosed out the intercooler...maybe not.
Old Apr 20, 2016 | 01:08 PM
  #1449
Atomic's Avatar
Well so it turns out I forgot how to take the area of a circle so I traded for the wrong jets When I got the ones I told them I wanted in hand I thought no way is this right, and sure enough, way too small.
Made a new spreadsheet, this one makes a lot more sense as to being realistic.
Also jut for fun, a 15GPH nozzle measures roughly 0.045", which is the same size that would support about a 250hp nitrous shot.
File Type: xls
Old Apr 20, 2016 | 01:43 PM
  #1450
GM1697's Avatar
you and the spread sheets...
