I hope I'm not late for work!
Old Dec 13, 2015 | 07:19 AM
  #1221
Atomic's Avatar
I have a gauge for that
Standard belt configuration and it's a 04+ pump. It's the one I put the rod through the snout and welded the end.
Old Dec 13, 2015 | 12:56 PM
  #1222
BlackGMC's Avatar
Resident Retard
So the waterpump you busted was it a reman or factory? The reason i ask is if it was reman iassume they removed the pulley to rebuild it thus loosening the press fit tolerances. I know along time ago i tried to remove the pulley on a ls1 pump. I had to weld the 3-jaw puller to the pulley to install a truck pulley. That orginal pulley did not want to come off. Just thinking out loud. That was my reasoning for buying a brand new ACDelco pump when I installed my SC.
Old Dec 13, 2015 | 01:44 PM
  #1223
Atomic's Avatar
I think it was a reman, interesting theory actually. I know trying to get the power steering pulley off that one pump I had was literally impossible haha.
I think I found the source of the misfires, looks like 2 of the wires were burned on the headers. I hate plug wires.
Old Dec 13, 2015 | 01:50 PM
  #1224
GMCtrk's Avatar
You've had more issues with plug wires than I've ever heard of anyone else having.
Are you running MSDs with the bendable boot?
Old Dec 13, 2015 | 02:36 PM
  #1225
BlackGMC's Avatar
Resident Retard
If your shopping for plug wire i really like my taylors. Check out the room.
Old Dec 13, 2015 | 03:48 PM
  #1226
Atomic's Avatar
Well the passenger side is fine with summit wires, but the back 3 on the driver side is tight around the header. I actually have some of those Taylors and I shortened them to get the bend tighter so it clears the pipe. Everything should be good now, nothing is touching anywhere and they all have heat shields on them.
Old Dec 13, 2015 | 08:04 PM
  #1227
myth's Avatar
Hey Richard. The only thing I see that you might run into with the belt routing is super charger belt slip from the lack of belt wrap.
Old Dec 13, 2015 | 08:06 PM
  #1228
Atomic's Avatar
Oh the picture above is just to show how it would go with the other idler in there putting the waterpump on the easy side of the system. I would need a longer belt to wrap under the other idler. I wouldnt run it as pictured.
Old Dec 13, 2015 | 08:08 PM
  #1229
myth's Avatar
I use to run as much belt wrap as possible when I had my cobra and would still get belt slip.
Old Dec 29, 2015 | 07:02 PM
  #1230
Hulign's Avatar
Digging up an old part of this thread but can you tell me what size/brand the pulleys are in this pic? Is this a stock Maggie bracket or was it modded for these?
Thanks!
Originally Posted by BlackGMC
I wonder if you could just buy a maggies pulley assembly bracket?
