I hope I'm not late for work!
Old Nov 15, 2015 | 07:25 PM
  #1131
Bowtie502's Avatar
Originally Posted by Atomic
Yep, decided to keep it going instead of making another one for the blower build. I guess the second setup for this truck if you just count turbo or blower....but for the truck, went through 3 turbos and now this blower, and had some engine parts replaced along the way.
By the way, you need to call your twin and harass him for not setting up a meet this year.
Yeah I text gayrat the other day asking if there was a meat this year I was like awww damn
Old Nov 16, 2015 | 11:09 AM
  #1132
sprayedenali's Avatar
So how do you control idle rpm? Just with spark?
just with the idle RPM and throttle body. same way it was done for years before fancy IAC motors!
Old Nov 16, 2015 | 11:15 AM
  #1133
Atomic's Avatar
I have a gauge for that
You mean the idle set screw? You need something else as well, has to be some spark compensation somewhere in there...
Old Nov 17, 2015 | 10:43 AM
  #1134
Bumpers's Avatar
I say we just plan it and show up at his house like normal
Old Nov 17, 2015 | 11:08 AM
  #1135
well ill set the itming in the idle parameters, set the idle rpm in the tune and then use the set screw to get it there. works like a charm.
Old Nov 23, 2015 | 09:37 PM
  #1136
Atomic's Avatar
So I ported the IAC pathway in the entrance and exit and even drilled it out to 9/16", which I think I did it too much since now the IAC isnt able to go far enough to full seal the bypass. Its not terrible though, just turned the set screw back some. Its still loud as ****. I give up.
On another note, lets play wheres waldo!
And yes it was tac welded...
Old Nov 23, 2015 | 09:40 PM
  #1137
GMCtrk's Avatar
time to break out the welder
Old Nov 24, 2015 | 01:02 AM
  #1138
Vortec350ss's Avatar
Damn... Im glad I haven't had this problem yet.
Did you turn down your idle at all? May make things better.
Old Nov 24, 2015 | 06:31 AM
  #1139
Gadgetized's Avatar
I remember Mike from New Era was having the problem of losing water pump pullies. He ended up going with an aftermarket pump from PRW that has a 4 bolt hub.
Old Nov 24, 2015 | 07:17 AM
  #1140
BigKID's Avatar
I also have a PRW water pump. No problems thus far but I never had a tacked stock water pump pulley come off either.
