C3 build
Old Aug 8, 2012 | 08:45 PM
  #661
03sierraslt's Avatar
Or if you have a infa red thermometer then shoot each primary to see if you have a cool cyl.
Old Aug 9, 2012 | 10:46 AM
  #662
black00chev's Avatar
Slowest turbo build ever!
Or if you dont have one... Get a water bottle, poke a tiny hole in the top and shoot the water on the primary. If it doesnt boil off, then you found your problem cylinder.
Old Aug 9, 2012 | 01:19 PM
  #663
oakley6575's Avatar
Or touch each primary and see which is the coolest.
Old Aug 9, 2012 | 02:08 PM
  #664
Try licking each primary, you tounge is heat sensitive. If you find one that doesnt make you cry then u have a issue.
Old Aug 9, 2012 | 02:10 PM
  #665
smokeshow's Avatar
Mod with training wheels
Try not to burn your face though. Your forehead will probably get real close to the other primaries.
Old Aug 9, 2012 | 02:12 PM
  #666
oakley6575's Avatar
From my past experience, you can use a different finger for each primary. Then just compare burn marks. It is easy and free. Can't beat that
Old Aug 9, 2012 | 02:31 PM
  #667
AndysC3's Avatar
LOL, I already have a water spray bottle. Ill try that first. Could this be caused by a broken valve spring? They are patriot Duals. There was hardly any load when it happened. Dont even think I was in boost. Maybe 1-2psi max. Coolant was about 203 IAT was around 120 and AFR was 12.3. And I just got on it a good bit up the road. I also ordered some FIC 1000 injectors.
Old Aug 9, 2012 | 02:54 PM
  #668
Does it have a missfire? How lean is it at idle? If its like 19 afr it shouldn't idle for **** UNLESS you got one cyl lean throwing off the reading and the others are ok.
Old Aug 9, 2012 | 03:05 PM
  #669
AndysC3's Avatar
Idle will jump from 16-17 to 19. I'll take quick log and post it up
Old Aug 9, 2012 | 03:25 PM
  #670
AndysC3's Avatar
Im not seeing any misfires on the Aeroforce Interceptor gauge. Ill hook up the efilive scantool and look for a mis.
Do I want to log current of history misfire?
