C3 build
Old Mar 8, 2013 | 04:41 PM
  #1161
SCREAMINXL's Avatar
Since you installed a new non-spliced wire the voltage drop will probably be less than .5 volts.
Resistance for what you’re checking only confirms continuity of the wire.
To perform a voltage drop on the wiring to the pumps. Set the DVOM to DC voltage, put one lead on the start of the wire and the other lead at the pump. You should see less than a 10% drop on the wire, example 1.37 volts would be 10% of 13.7 volts.
Congrats on getting the pumps installed and wiring cleaned up. It looks really good! I hope the weather holds so you can get some track results.
Good Luck.
Old Mar 8, 2013 | 04:54 PM
  #1162
AndysC3's Avatar
I wired the primary pump to the battery in the bed. The power wire is maybe 4 ft long the ground is only 2.5 ft long. It works very well. Can't wait for the track tomorrow
Old Mar 8, 2013 | 04:55 PM
  #1163
ak2007r6's Avatar
What's your prediction at the track??
Old Mar 8, 2013 | 04:57 PM
  #1164
AndysC3's Avatar
Hoping for about a 12.3-4 at about 110
Old Mar 8, 2013 | 04:58 PM
  #1165
ak2007r6's Avatar
Good luck! Looking forward to some videos!
Old Mar 8, 2013 | 06:48 PM
  #1166
smokeshow's Avatar
Mod with training wheels
Supposed to be 43° tomorrow when the gates open. If it doesn't rain or snow it should be easy to make some good power.
Old Mar 8, 2013 | 07:13 PM
  #1167
ak2007r6's Avatar
Damn.. great boost weather.
Old Mar 8, 2013 | 07:16 PM
  #1168
darnie's Avatar
dam wish i could make it in for vids
Old Mar 8, 2013 | 07:18 PM
  #1169
AndysC3's Avatar
But the da will still be over 2000'. My 12.7 had a da of 4100' so it should be fun.
Old Mar 8, 2013 | 10:50 PM
  #1170
AndysC3's Avatar
http://i663.photobucket.com/albums/u...psb900fd3b.mp4
Some testing. Getting about 11.5-11.8 psi. Almost ready for the track
