C3 build
Old May 19, 2012 | 08:05 AM
  #301
AndysC3's Avatar
So what's needed to make a 80e last behind about 750whp in a 5400# truck? Will a stock 80e with shift kit be enough?
Old May 19, 2012 | 08:59 AM
  #302
Stoichiometric's Avatar
With a shift kit and proper tuning the 80e should handle 750whp no problem. The transmission is similar to running boost through an engine. Forged parts in the engine or a larger trans (80e) will buy you headroom, but if the engine detonates of the trans shifts too hard/soft they can both come apart. Just watch the 1-2 shift to make sure you do not have excessive pressure that can cause the sprag to roll over.
Old May 19, 2012 | 09:30 AM
  #303
AndysC3's Avatar
Thanks. Is there anything else I should replace while its at the builders?
Old May 19, 2012 | 09:31 AM
  #304
ak2007r6's Avatar
Can't wait to see this truck with booooooost!
Old May 20, 2012 | 12:18 AM
  #305
AndysC3's Avatar
Yea, I can't wait. I'll probably do boost first, just keep it low while I get the 80e built. Just need to find a good core. All the ones I'm finding are shops that want 1500+ and a core. Or 94-95 models with 250k miles on em.
Old May 20, 2012 | 12:26 AM
  #306
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by smokeshow
GMC3 is running a 60e with a procharger on 11psi. Not sure of the longevity, but he is making it work. And yeah, those first gear downshifts at 40mph are pretty insane...
He's been having the 60E blues as well. 3-4 clutches just don't last long with a decent power-to-weight ratio. He's been asking me about the 80E conversion.
Old Jun 12, 2012 | 10:13 AM
  #307
AndysC3's Avatar
A few of the members here know that I've been considering changing my setup to run a turbo. Most likely start with a trick stage 3 and upgrade the turbo later down the road. And have the 4c restalled to about 3k.
Or I can keep the current setup and get a d1sc.
Both will cost about the same but will have less down time with the procharger. Mpg would be alittle easier but that's not that big of a deal to me. What is Yalls advice?
Old Jun 12, 2012 | 10:54 AM
  #308
ak2007r6's Avatar
I am biased but I think with the setup you have right now a D1 would be ******* killer...
That 4k stall with a D1 and your gears would be brutal off the line
Old Jun 12, 2012 | 02:20 PM
  #309
rjwz28's Avatar
Man Motor club
I agree. Turbos are sweet but the D1 would be much quicker to have set up as you already have the proper supporting mods.
Old Jun 12, 2012 | 02:33 PM
  #310
smokeshow's Avatar
Mod with training wheels
I'm gonna be selfish and say that I want to see what a D1 can do on your truck...lol
