C3 build
Old Jun 22, 2013 | 10:34 PM
  #1321
AndysC3's Avatar
its just some slight surface rust. it wiped clean with a rag. I have rags in all of the open ports and cylinders now
Old Jul 12, 2013 | 10:09 PM
  #1322
AndysC3's Avatar
Looks like the #3 piston came out of the cylinder a bit and kissed the head
Old Jul 14, 2013 | 08:36 PM
  #1323
darnie's Avatar
No buano! Whats ur plans..... need to catch me up
Old Jul 15, 2013 | 10:34 PM
  #1324
AndysC3's Avatar
Going back to stock. Already sold off a few of the performance stuff. Looking for a replacement motor. Then I have to figure out what the truck is worth on the market here and decide if its worth it to sell it. Already traded my wife's Jetta for an 06 chevy equinox. So the family vehicle is covered. Wish there was a machine shop around here that could just fix my motor vs having to buy another one to swap in
Old Jul 16, 2013 | 06:52 AM
  #1325
silver-mod-o's Avatar
Hunt&Fisherator
Why does your coolant look like swamp water?
Old Jul 16, 2013 | 02:20 PM
  #1326
AndysC3's Avatar
Not sure. There is a crack in the drivers side end tank next to the oil cooler lines. Oil may have gotten into the coolant. I had to top of the overflow tank about once a week. I also put some of the stop leak stuff on the coolant to help seal up the crack. What would cause the piston to make contact with the head? A stretched/broken rod bolt? If so what all needs to be replaced? Piston, rod and bearings of the affected rod? How much would that cost at a machine shop
Old Jul 17, 2013 | 01:09 AM
  #1327
oakley6575's Avatar
I would guess you most likely floated the motor since you spin it so damn high.
Old Jul 17, 2013 | 11:21 AM
  #1328
darnie's Avatar
Hopefully you can find a machine shop then get ya a single cab
Old Jul 17, 2013 | 12:18 PM
  #1329
AndysC3's Avatar
Floated the motor? Do you mean flooded? If so would t that bend the rod and make it sit deeper in the cylinder? It's flush with the deck like the other pistons.
And I have a single cab now. Lol.
Has anyone used a 2ton engine hoist from harbor freight? It's about my only option since I don't have the extra 300 for a name brand one. I'm using one of their 6ton bottle jacks and its awesome. But the engine hoist is a little more scary. I have a coupon and can get it for 130 shipped. Thanks
Old Jul 17, 2013 | 02:30 PM
  #1330
oakley6575's Avatar
No.. I mean floated the motor. The valves probably floated and contacted the piston
