C3 build
#1231
I don't know what your running for fuel but if your wanting more power I would do some e85 or meth and up the timing if your not already. You can also pulley down and do a overdrive crank pulley to really make that d1 come alive .
#1236
As long as your running one of two thats good.I doubt your even cracking 600rwhp I would bet your closer to the 550+ range with 110 mph trap speed. You just need to pulley down and run some boost ! What you waiting for!??! Get your self a 10% overdrive crank pulley and get a 3.5 pulley on the head unit. What kind of BOV are you running?Seems llike you should be hitting around 14 psi with a 3.6 on that thing. What are you shifting at ? Have you done a leak test on your intercooler tubing?
#1237
I know this is just a calculation but they seem to be pretty accurate. But this is at 600hp, 5400lbs, 3 shifts, 32.6" tires and 4.56 gears
its right along with all of my times.
that was peaking at 12 psi in Tucson. My one short WOT run that I did here in Minot ended at 6700 rpm and 12.8 psi. still had 200 rpm to go. So Im looking for a 3.5 or a 3.4" pulley. I kinda dont want to get a different crank since this one is already keyed.
#1239
I think that calculator is a bit off, eventhough in Tucson I could only trap 96-96 n/a, but the effect shouldn't be as bad on a boosted motor. Looking at some online calculators, I'm coming up with around 515 rwhp. Seems a little low for a 6.0 on 12 psi. Although you are AWD thru an 80e...
