C3 build
Old Feb 11, 2013 | 07:00 PM
  #1131
03sierraslt's Avatar
Are you still running a stock tensioner? What all alternatives are there for you procharged guys?
Old Feb 11, 2013 | 07:06 PM
  #1132
Mangled03gmc's Avatar
Baltimore Whore
I do not think I have ever seen anyone deal with a boost issue to such and extant. You have to take into consideration the pulley that you are putting on is based on a stock engine for boost numbers. So you have def free'd it up a great bit, therefore boost is going to vary. If the new IC didn't affect it then it is prob legit. Have you tried switching boost gauges, to see if your current one might be bad? I have been running the same belt now for over 2 years( gates HD) and I do not think I am seeing any slip, I believe I am running a 3.5 pulley, am seeing right about 13-14 on the shifts. Of course my belt is TIGHT, I am still using a stock tensioner also..
https://www.youtube.com/watch?v=SEh6I-7_E6U
Old Feb 11, 2013 | 07:09 PM
  #1133
Andy, if you can find a HD belt in the size you need get one. They are much better at resisting stretch and in turn make it easier to keep your tension correct.
Old Feb 11, 2013 | 07:38 PM
  #1134
AndysC3's Avatar
I have a gator back belt on it now. I got a gates belt form napa. My gauge shows 10-10.5 but the map sensor only shows about 9.5-10 then drops at 6300
Old Feb 11, 2013 | 07:39 PM
  #1135
AndysC3's Avatar
I'm needing a 113.5 but I can't find one. I may tray the 113 but it will be very tight
Old Feb 11, 2013 | 07:40 PM
  #1136
AndysC3's Avatar
Mangled, what are you shifting at?
Old Feb 11, 2013 | 07:46 PM
  #1137
Baltimore Whore
I believe it is ruffly 62-300..
Old Feb 11, 2013 | 07:47 PM
  #1138
smokeshow's Avatar
Mod with training wheels
MAP will never match the gauge exactly... Post up a screenshot of your boost dropping at 6300.
Old Feb 11, 2013 | 07:48 PM
  #1139
AndysC3's Avatar
I'll post it when I get home
Old Feb 11, 2013 | 07:52 PM
  #1140
Ya, my MAP and gauge don't match 100% either. IIRC I think one is off by .5lb or so.
