C3 build
Old Dec 3, 2012 | 04:32 AM
  #1011
rjwz28's Avatar
Man Motor club
Looks good. What route are you going to repair the scratches? I've torn mine up in a couple spots and want to have a plan for whenever I decide to fix all the scratches and chips my adventures have produced.
Old Dec 6, 2012 | 02:28 AM
  #1012
AndysC3's Avatar
For now Im going to clean it up and plastidip the whole truck. if I like it I may paint the truck flat black
Old Dec 6, 2012 | 02:34 AM
  #1013
AndysC3's Avatar
What size meth nozzle should I get? Looking for about 12psi. Start spraying around 4psi
Old Dec 6, 2012 | 02:54 AM
  #1014
Mangled03gmc's Avatar
Baltimore Whore
Meth at only 12 Also I hope that is not a gator back belt, if it is kiss it good bye after a good rhomp, lift fast.
Old Dec 6, 2012 | 03:50 AM
  #1015
AndysC3's Avatar
Lol, after seeing my iat go from 100-170 in 8 sec at 10psi, it was time for a better intercooler and I have the meth pump and controller already. I just ordered a 12.8 gph nozzle, 10' of clear tubing, and some 90* 1/8npt fittings, and 1/4" quick disconnect fittings. Going to use the washer reservoir for the tank. What's the best way to tap the tank. Thinking about drilling and tapping for 1/8npt and installing one of the qd fittings with some rvt sealant.
And it is a gatorback. I've had more issues with the tensioner than the belts. Looking into one of the gates green belts right now.
Old Dec 7, 2012 | 12:28 AM
  #1016
AndysC3's Avatar
Moved my truck to my buddies garage. Only have about a 1/2" clearance front and back. Going to remove the rear number to give alittle more clearance. Going to start removing the 60e and getting it ready for the 80e. Should have the 80e back this weekend. So hopefully will be back on the road by next weekend with some new videos.
Old Dec 7, 2012 | 03:30 PM
  #1017
black00chev's Avatar
Slowest turbo build ever!
Are you going to have to change driveshafts with the swap? Gonna start looking into the swap myself come spring.
Old Dec 7, 2012 | 03:36 PM
  #1018
milkey57's Avatar
Ever get that new cam?
Old Dec 7, 2012 | 04:21 PM
  #1019
AndysC3's Avatar
Yes, the drives shafts will need to be changed. The front needs to be longer and the rear need to be shorter. About 1.5-1.75" from what I've read.
Still running the same cam.
I measured my stock drive shaft. 5" in diameter and about 68.5" from yoke to yoke.
Old Dec 18, 2012 | 03:18 PM
  #1020
AndysC3's Avatar
Things have been moving kinda slow with the truck but its almost done. I picked up a 4L80E 4x4 adaptor which is about 2" shorter. But my bolts to mate it to the trans were too long. so I made a trip to Ace hardware and picked up some grade 8 studs and nuts. worked great and made the install much easier. I also use blue locktite to make sure they stay in place. the HD front drive shaft is a perfect fit and is smaller in diameter so it clears the NSS very well. For the rear, when the drive shaft is all the way in the tcase its about .5" too long, so Im going to have it cut and shortened about 1.5" and rebalanced. Im still waiting on the lower bellhousing to show up and I need to get a VSS pigtail. I swapped the white and brown wires in the main control harness. wasnt as bad as I though it would be. and I need to make a trip to the dealer and pick up some tcase fluid. hoping to have it on the road by this weekend.
