Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Jun 10, 2010 | 03:04 AM
  #51
Blown06's Avatar
8 Second Truck Club
Got some pics of the rearend. O' and if any of you didn't realize it I have a procharger for sale.
Old Jun 10, 2010 | 09:10 AM
  #52
CharlyNali6.2's Avatar
^^^gaaaawwwddd damn that looks crazy but i like it!!!! awesome progress!!
Old Jun 10, 2010 | 09:34 AM
  #53
JoeyGC5's Avatar
Are there going to be any clearance issues with the torque arm mount tabs, or will they be removed?
Old Jun 10, 2010 | 10:12 AM
  #54
Blown06's Avatar
8 Second Truck Club
There shouldn't be any issues with clearance, but damn that thing looks like an eye sore now. I'd leave the bracing on thats built around the housing, but if Madman doesn't do it, I'll probably cut the original torque arm tabs off, just to make it look a little better.
Old Jun 10, 2010 | 11:05 AM
  #55
Phantom's Avatar
11 Second Club
Man I mean absolutely no disrespect, BUT...aren't you the least bit worried about spending all this money and still having a 10bolt?
Old Jun 10, 2010 | 11:36 AM
  #56
bluecajun5.3's Avatar
11 Second Truck Club
i would remove all that boxed in stuff for that tq arm idea. that's got to be adding some weight there.
Old Jun 10, 2010 | 12:33 PM
  #57
mad_steve's Avatar
LS1Tech Sponsor
the torqe arm tabs won't be in the way of anything, but I can see if the boss will let me cut them off, if you don't want em on there. Also, i'll have some more pictures to you soon of the plates i'm welding in to box the frame.
Old Jun 10, 2010 | 12:57 PM
  #58
Daryn's Avatar
Formerly darynC-10/23/10
his truck is at madmans. the thing will be perfect when it leaves.
Old Jun 10, 2010 | 02:42 PM
  #59
Blown06's Avatar
8 Second Truck Club
It was an issue of dollars and cents. I went a little over budget as it was already at the chassis shop, however I figured that while it was there it would be best to get as much done as possible, instead of making numerous trips and redo's. Once the 10 bolt goes out, I'll have the crew at Madman's build me a 9" housing that I can just basically bolt in. The extra cost of the housing, axles, center section and brakes was probably going to take me over the edge.
I agree. Let me see if they'll do it.
Steve, while your at it, Brian had mentioned that you guys were going to weld a brace across the back of the rearend. If so can yall just cut all that extra crap off? It couldn't add too much extra to the bill could it?
Old Jun 10, 2010 | 04:39 PM
  #60
mad_steve's Avatar
LS1Tech Sponsor
I'll have to check with the old man before I can make any promises.
