Blown 408(literally)
Old Aug 10, 2010 | 11:12 AM
  #111
Atomic's Avatar
I have a gauge for that
The holes are interchangeable, just the 80e plate has an extra one in between the normal 60e holes. Coban is right about the differences. id just use the one off your 5.3. It will be right, make sure you use lock tite on the fp bolts they WILL back out
the bolts on the tc or crank?
at least this way I have an 80e flexplate and spacer if I ever do the swap
Old Aug 10, 2010 | 11:21 AM
  #112
Dezert1500's Avatar
On the TC
Old Aug 10, 2010 | 08:43 PM
  #113
Atomic's Avatar
Originally Posted by Bumpers
i cant remember if i loctited mine or not
egine looks good
Ill raise you a blower
Heres my swap setup f*ck alabama summers
Almost have the 5.3 out. Just have one bellhousing bolt, driver side motor mount, and a rounded off torque converter bolt. I think im going to take my dremel to that bolt and just detroy that piece of ****. Loctite can blow me.
Old Aug 10, 2010 | 08:55 PM
  #114
Bigredmariner's Avatar
Making nice progress on that beast.
Old Aug 10, 2010 | 09:09 PM
  #115
2005 Silverado's Avatar
SPAM HUNTER
looks good! Much easier on a lower truck though...just saying Or pull the wheels and put the front as low as possible
Old Aug 10, 2010 | 09:14 PM
  #116
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I meant loc tite on the fp to crank bolts. I NEVER put loc tite on the tc bolts unless it is an ARP bolt as the stockers tend to be soft and round off like yours. Id rather pull the starter and tighten tc bolts than a trans to tighten fp bolts.
Im really interested to see how this turns out
Old Aug 10, 2010 | 09:35 PM
  #117
Atomic's Avatar
Im really going to be pushing it to clear the top rad support with my crane so I think I may take the wheels, tires, and rotors off and lower it down to the LCAs...
Anyone have any suggestions for that TC bolt before I cut it like its emo with the dremel?
Old Aug 10, 2010 | 09:47 PM
  #118
dlt76028's Avatar
See if you can work one size smaller on it, or a standard size.
Old Aug 10, 2010 | 09:55 PM
  #119
built408's Avatar
An air hammer always does the trick for me on rounded converter bolts.
Old Aug 10, 2010 | 09:58 PM
  #120
Atomic's Avatar
Hmm I may try the standard size since the 15mm now just slips right off. I tried using an impact with a lot of extensions so the impact was in front of the centerlink and im laying under the truck holding the socket on the bolt with my left hand and working the impact with my right. Too bad that didnt work
I dont have an air hammer.
