Blown 408(literally)
Old Aug 9, 2010 | 09:25 PM
  #101
2005 Silverado's Avatar
SPAM HUNTER
you have a 408, it has a stroker crank...you dont need a spacer, no aftermarket company would make a crank for limited use it would lose them money...
Nice build though.
Old Aug 9, 2010 | 09:26 PM
  #102
dlt76028's Avatar
Originally Posted by Atomic
the problem im having now is when i torque the flexplate down it hits the block and rear cover bolt heads...
Hmm well maybe it needs the spacer then. Maybe I switched the stock 4.8 flexplate with the 6.0 flexplate? Does your 5.3 have a spacer?
Old Aug 9, 2010 | 09:30 PM
  #103
SPAM HUNTER
my previous statement stands, but thats not right...at all...
  #104
Atomic's Avatar
I have a gauge for that
I dont have my 5.3 out yet, but will hopefully tomorrow, so I cant comment on what the 5.3 has just yet.
2005, what is the flexplate for that is pictured on the previous page?
Old Aug 9, 2010 | 09:37 PM
  #105
SPAM HUNTER
im pretty sure its a regular flywheel...are you sure you had it the right way? not trying ot be a dick trying to help. i know of no differences in the 80e and 60e plate, just the spacer...
Old Aug 9, 2010 | 10:40 PM
  #106
Atomic's Avatar
I had the side marked engine side toward the engine so im pretty sure I had that right...the spacer is flat in any even so it wouldnt really matter except the slightly raised parts for the torque converter.
Old Aug 10, 2010 | 07:23 AM
  #107
Coban's Avatar
60e flexplate is dished and is used without spacer. 3 bolts for TC.
80e flexplate is flat and needs a spacer. 6 bolts for TC. This is what's in the picture.
Old Aug 10, 2010 | 08:24 AM
  #108
Atomic's Avatar
Thanks, and im guessing the bolt holes are not the same on both the 60e and 80e, right?
Old Aug 10, 2010 | 09:11 AM
  #109
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The holes are interchangeable, just the 80e plate has an extra one in between the normal 60e holes. Coban is right about the differences. id just use the one off your 5.3. It will be right, make sure you use lock tite on the fp bolts they WILL back out
Old Aug 10, 2010 | 10:03 AM
  #110
Bumpers's Avatar
i cant remember if i loctited mine or not
egine looks good
