BlackGMC build take 3 - Supercharger Time
Old Nov 4, 2016 | 01:47 PM
  #711
1FastBrick's Avatar
Custm2500's Rude Friend
It's already on, Why don't you test it?
Old Nov 4, 2016 | 01:50 PM
  #712
BlackGMC's Avatar
Resident Retard
Daughter is asleep and i am home alone
Old Nov 4, 2016 | 01:54 PM
  #713
1FastBrick's Avatar
ok macaulay culkin...
Are you afraid that you need a whipple?
Old Nov 4, 2016 | 01:56 PM
  #714
BlackGMC's Avatar
Resident Retard
Whipple.... wtf for?
Naw i should be able togo drive it shortly. Then it is coming back off so my buddy can use it and test it.
Old Nov 4, 2016 | 02:06 PM
  #715
1FastBrick's Avatar
You know what for... https://www.performancetrucks.net/fo...vs2650-546536/
Old Nov 4, 2016 | 02:08 PM
  #716
BlackGMC's Avatar
Resident Retard
Yeppers. If they had a ls hot rod kit out i would be ordering it. But they dont. So i will just continue to look at ****.
Old Nov 4, 2016 | 03:11 PM
  #717
BlackGMC's Avatar
Resident Retard
Soooooo i took it for a drive.
Only tune change i made was to the etc scalar.
I have the new version of the xlink so i did not have to cut the wire to switch from ls2 to ls3 electronics.
It starts up just fine. No issues
It idles just fine. No isssues
Normal driving is basically the same as the ls2 tb. No issues.
Wot i gained 1 psi from this morning log and that was not even pushing really the new setup that hard.
193kpa to 200kpa. Most boost i have ever seen in the past was 195kpa on this setup.
So from my breif experience no issues at all. This about as apples to apples comparison i can do.
It does have some more part throttle grunt/power to it. At wot you also hear the blower alot more.
So eventually i will ditch that tb adapter and port the snout. Perhaps it will gain more boost!!!
Old Nov 4, 2016 | 03:13 PM
  #718
Vortec350ss's Avatar
Awesome! Great results and right in line with that I expected. Man I wish I had my hands on a 102 that worked last weekend...
Old Nov 4, 2016 | 03:15 PM
  #719
1FastBrick's Avatar
Good to know!
Old Nov 4, 2016 | 04:57 PM
  #720
Atomic's Avatar
I have a gauge for that
Is your MAP sensor maxed out at 200kpa? Blowers are very sensitive to pre-rotor pressure loss so I am sure you gained some power going up in boost.
