BlackGMC build take 3 - Supercharger Time
#616
A little comparo for you.......I have about 30 timeslips from my truck running 99-102 mph in the 1/8th. It was 4550 lbs and probably 700-750 rwhp at the time. Can't guess better than that, never dyno'd it.
This is a rcsb right? I'd think 650 is probably a good number.
#617
Corey, with a smaller cam and similar boost maybe a tad less Tims truck put down like 630/630 in second gear. So a true third gear pull would have been more.
That's through a transfer case also.
#618
Where are you mounting this? New motor mounts are stupid expensive, this might be a good investment.
Edit. Nm I see alt bracket and Frame rail. Hmmmm
The reviews on Amazon for the Ac delco are bad. People said they were junk and had to replace them w gm units.
#620
Resident Retard
I got my IAT sensor in the intake tube installed and the fluid temp sensor installed in the exit of the HX all wired up today.
New IAT sensor in the intake tube reads ambient when cruising. Parked it climbs about 10* above ambient.
IAT sensor in the blower reads about 10-15* above ambient while cruising.
The HX sensor reads the same temp as ambient while cruising and WOT. Parked it climbs about 10* above ambient.
Sooooo that is interesting.
