BlackGMC build take 3 - Supercharger Time
Old Oct 31, 2016 | 08:20 PM
  #691
BlackGMC's Avatar
Resident Retard
Originally Posted by Blown06
Can you pull the snout off and take some pics of exactly where you need the machine work done? Or if you already have some pics email them to me. I can get you fixed up with the machine work.
email is travis_wenske@
yahoo.com
I will tru to take it apart this weekend to take some measurements and pics.
mine was machined prior to me owning it.
The adapter should add enough depth to make it work.
The adapter is just to see if the TB is gonna work. That snout will get opened up
Old Nov 2, 2016 | 08:44 AM
  #692
DrX's Avatar
DrX
Originally Posted by BlackGMC
They added a steel gear that attaches to the TB Blade. The other one was some kinda plastic.
Is this actually different than the old version of the 102, or did they change something else.
Old Nov 2, 2016 | 09:32 AM
  #693
BlackGMC's Avatar
Resident Retard
It is different from stock. That is all i know. I requested info on what changed they said it was proprietary.
Old Nov 2, 2016 | 10:35 AM
  #694
TXsilverado's Avatar
yeah the NW 102 is HUGE (externally). now I know what to look for on my TB to see if it's the "boost" version. can I buy just the metal gear somewhere? I hear that NW is hard to get ahold of.
Old Nov 2, 2016 | 11:20 AM
  #695
DrX's Avatar
DrX
I am wondering if the gear is the same for all versions of the NW102 due to having a longer shaft. Also, I think the hub of the OE gear is welded to the shaft in the LS3, so it may not be re-usable.
Old Nov 2, 2016 | 07:14 PM
  #696
BlackGMC's Avatar
Resident Retard
New Flanges
Adapter 90mm to 102mm. Using this just to test the TB
Straight 102mm to use as a quide when i port the snout.
Old Nov 3, 2016 | 01:18 PM
  #697
Vortec350ss's Avatar
They look great. When will the 102 make it on?
Old Nov 3, 2016 | 01:46 PM
  #698
1FastBrick's Avatar
Custm2500's Rude Friend
Could have a gear made...
Old Nov 3, 2016 | 01:54 PM
  #699
BlackGMC's Avatar
Resident Retard
Huh??
Old Nov 3, 2016 | 01:57 PM
  #700
1FastBrick's Avatar
I was referring to this.
He could have one made
