BlackGMC build take 3 - Supercharger Time
Old Aug 22, 2016 | 08:44 AM
  #611
Atomic's Avatar
I have a gauge for that
96mph in your truck will take about 650rwhp for what its worth
Old Aug 22, 2016 | 08:48 AM
  #612
BlackGMC's Avatar
Resident Retard
Gotcha. Probably 100hp short
Old Aug 22, 2016 | 10:11 AM
  #613
TXsilverado's Avatar
my extended cab was hitting 94 mph at roughly 550 RWHP
Old Aug 22, 2016 | 10:52 AM
  #614
03sierraslt's Avatar
Highly doubt it.
Old Aug 22, 2016 | 12:01 PM
  #615
BlackGMC's Avatar
Resident Retard
I was always horrible at quessing HP and track times. I have no clue. Some day i might toss it on the dyno.
Old Aug 23, 2016 | 12:28 AM
  #616
Blown06's Avatar
8 Second Truck Club
A little comparo for you.......I have about 30 timeslips from my truck running 99-102 mph in the 1/8th. It was 4550 lbs and probably 700-750 rwhp at the time. Can't guess better than that, never dyno'd it.
This is a rcsb right? I'd think 650 is probably a good number.
Old Aug 23, 2016 | 07:22 AM
  #617
Corey, with a smaller cam and similar boost maybe a tad less Tims truck put down like 630/630 in second gear. So a true third gear pull would have been more.
That's through a transfer case also.
Old Aug 23, 2016 | 09:47 AM
  #618
Choda's Avatar
The adjuster for my engine strap finally showed up today. I think i am gonna shorten the threaded portions some.
Where are you mounting this? New motor mounts are stupid expensive, this might be a good investment.
Edit. Nm I see alt bracket and Frame rail. Hmmmm
The reviews on Amazon for the Ac delco are bad. People said they were junk and had to replace them w gm units.
Old Aug 23, 2016 | 10:13 AM
  #619
BlackGMC's Avatar
Resident Retard
Interesting. My ac delco one look pretty nice and have actually stopped
The engine movement by themselves.
Old Sep 10, 2016 | 04:29 PM
  #620
BlackGMC's Avatar
Resident Retard
I got my IAT sensor in the intake tube installed and the fluid temp sensor installed in the exit of the HX all wired up today.
New IAT sensor in the intake tube reads ambient when cruising. Parked it climbs about 10* above ambient.
IAT sensor in the blower reads about 10-15* above ambient while cruising.
The HX sensor reads the same temp as ambient while cruising and WOT. Parked it climbs about 10* above ambient.
Sooooo that is interesting.
