BlackGMC build take 3 - Supercharger Time
#621
So on a cold engine (>12 hours to cool off), do the HX and IAT sensors read about the same (within 2 degrees) with the engine off?
Your results make sense really...the HX isnt the bottle neck, the intercooler under the blower is.
#623
Resident Retard
So interesting results.
Roughly 82* ambient temps
First startup, completely cold
Intake temp 80*
Iat 82
Hx temp 82
Cruising basically the same as startup but when stopes HX temps start to rise maybe 5* tops depends on how long stopped but they start to rise almost instantly.
Drove 20min at 60mph the. Stopped and turned off teuck for roughly 20min
Restart
Intake temp 102
Iat 114
Hx temp 92
Hx temps did not start to come down until i was cruising at least 45-50mph. They slowly decreased but once i was at cruising speed they came down really quick.
Now i am wondering if a cowl hood would help cool down the IATs even more since air would be blowing directly on the supercharger case.
Intake temp 80*
Iat 82
Hx temp 82
Restart
Intake temp 102
Iat 114
Hx temp 92
#624
I have been considering a cowl hood for a while to help with under hood temps. I think this would surely help.
I wish there was a heat extractor setup that I liked. I would put one on each side of the hood. Not really a fan of any of them so far.
#627
To be honest, I wasn't expecting that much change, but it was there. I put the plate back on and bam temps came back up. Took the plate off and threw it in the trash can.
#628
Good info!
#629
It was "HUGE" on that pontiac. I'm pretty sure every vehicle is gonna respond a little differently. My truck for example probably wouldn't see a gain like that as it is very "roomy" under the hood.
#630
Too bad you can't spacer the rear of the hood up on these trucks without it looking dumb. (maybe you can't even do it regardless). But on many cars it's to easy to remove the rear weather stripping and space the hood up 1/4in with washers on the hood hinge to create a spot for hot air to escape.
right....
