BlackGMC build take 2 - Turbo Time
Old Apr 22, 2014 | 08:26 PM
  #561
GMCtrk's Avatar
I've never heard of an ID customer being sorry about their purchase. Yea it is the same bosch injector, and that argument has been beaten to death.
When you spend that much on injectors you alo need to validate your purchase.
Old Apr 22, 2014 | 08:31 PM
  #562
BlackGMC's Avatar
Resident Retard
Some might not me. You notice how long those FIC injectors lasted on my truck. I had no problems selling them at a huge loss.
Old Apr 22, 2014 | 11:16 PM
  #563
Blown06's Avatar
8 Second Truck Club
I'm a believer in ID. I could care less if the same injector is re branded and sold cheaper............
Old Apr 28, 2014 | 09:13 PM
  #564
BlackGMC's Avatar
Resident Retard
More parts came in today. I ordered a new set of plug wires so i can shorten them. The previous set i had were the Taylor 409 Races series. Come to find out they carry a 330 Ohm per foot resistance. The new set are Taylor ThunderVolt 50 10.4mm Spark Plug Wires they carry a 40 Ohm per foot resistance. I have no clue on the differences but whatever. The thing i like about these wires is they accept the factory metal spark plug heat shields.
I had to shorten them about 1.5-2.0 inches to make them fit the way i wanted. Below is the before and after.
Here is the resistance measurement, 24 Ohm not too shabby!
Here is what they look like installed. From left to right. Stock GTO wire, stock taylor wire, next two are the shorten taylor wire.
Old Apr 28, 2014 | 09:19 PM
  #565
oakley6575's Avatar
Looks a lot better. All these little changes are going to make for a clean looking truck.
Old May 3, 2014 | 12:09 PM
  #566
BlackGMC's Avatar
Resident Retard
Working on the turbo side plug wires. Tons of heat protection. Maybe a bit overkill but oh well.
Standard wire
Boot cut off
New end crimped into the wire. Also i added a little heat shrink to the wire to help get it through the new boot
New boot installed along with some DEI heat shrink to help secure the new boot. Since these are 10mm wires it is really hard to get it into the boot. Some WD40 helps but sometimes the outer cover wrinkles a little bit.
More DEI heat shielding added to the wire
More DEI heat shrink added to the new wire.
This is what the roll of heat shrink looks like
Wires installed. Hopefully i will not ever have to worry about burning the wire.
Old May 3, 2014 | 12:13 PM
  #567
Choda's Avatar
Looks really good. I also did a plug wire test where ohm and fitment were measured.
Old May 3, 2014 | 12:16 PM
  #568
BlackGMC's Avatar
Resident Retard
Thanks man. Let me go take another measurement of the wire since it is shortened to see if it changed.
Old May 3, 2014 | 12:24 PM
  #569
BlackGMC's Avatar
Resident Retard
Retest results. Roughly the same
Old May 3, 2014 | 03:08 PM
  #570
BlackGMC's Avatar
Resident Retard
Passenger side harness done. Includes injectors, fpr sensor and iat sensor.
