Back in the game. RCSB 1500 D-max swap coming...
Old Mar 20, 2013 | 10:55 PM
  #131
907chev's Avatar
This such a cool idea.. Subscribing!!!
Old Mar 20, 2013 | 11:16 PM
  #132
_zebra's Avatar
makes children cry
but if they're inspecting based on a 99 gasser, mine had cats & i'd imagine they'll expect yours to.
that ain't to say the resonators on my LTs didn't pass visual
Old Mar 20, 2013 | 11:37 PM
  #133
1FastBrick's Avatar
Custm2500's Rude Friend
How's this look??? I have a red wire that I never hooked up for Power to trailer brakes and I also have a brake controller harness plugged into the top left of that white distribution block.
Attached Thumbnails Back in the game. RCSB 1500 D-max swap coming...-imag2475.jpg   Back in the game. RCSB 1500 D-max swap coming...-imag2476.jpg   Back in the game. RCSB 1500 D-max swap coming...-imag2477.jpg
Old Mar 20, 2013 | 11:58 PM
  #134
AKlowriderZ71's Avatar
11 Second Hall Moniter
IIRC, every harness and receptacle in the electrical center is shaped and pinned differently. I don't think you are able to plug anything into the wrong spot.
But I've been wrong before....
Old Mar 22, 2013 | 09:55 PM
  #135
thunder550's Avatar
High on diesel fumes
Got them all routed, thanks fellas
Interior is almost done. I should be able to finish it tomorrow, then on to the fun part
Swapping the wiring over was a bit of a PITA. They changed the footprint of the airbag sensor under the driver's seat, had to improvise a new stud. There are a couple of ground points that the crew cab wiring harness has that there aren't places for in the regular cab, so I had to drill a couple holes and put bolts in them to create grounds.
One question I had, since the donor is a crew cab, I have two connectors on each side of the body harness for the rear doors that I won't be using on the regular cab. I just tucked them behind the rear pillar panels. Will I have any issues like the truck thinking the rear doors are open or anything like that?
Also, the air bag sensor is actually labeled "crew cab". Why would they have a cab-specific sensor? Different sensitivity calibration or something?
Old Mar 22, 2013 | 09:59 PM
  #136
GMCtrk's Avatar
Damn, you're making fast work of this thing.
I remember back in the day when you had the blue xcab with the sc, then turbo setup. Seems like eons ago.
Old Mar 22, 2013 | 10:13 PM
  #137
thunder550's Avatar
Hah yep, blower, then turbo, then bigger turbo, then blower again...
I sold that back in 2009, that does seem like a long time ago.
Old Mar 22, 2013 | 10:55 PM
  #138
99LsSilverado's Avatar
I could see an issue with the door sensors and if not connected setting the door chime off. But a quick check would be to hook up a battery and turn the key on and see what it does
Old Mar 22, 2013 | 11:55 PM
  #139
1FastBrick's Avatar
I suspect you will have some trouble. You may be able to simulate the doors being closed but the calibration for the airbag is different between the sizes of vehicle. You might be able to eliminate the un-needed wires and sensors and have the calibration flashed in from a regular cab d-max truck.
Old Mar 23, 2013 | 12:38 AM
  #140
I'd think that the calibration in the SDM and BCM would need to match the components. In his case, it should, because he is using all of the parts from his donor vehicle. I'm guessing that GM has different components and calibrations for each of the 3 cab configurations, to deal with the different masses and inertias that happen in serious collisions.
Since he is using ALL of the parts from the donor vehicle, I don't think he will have any airbag system problems at all. Will the airbag system work as designed in a serious collision?? Maybe, maybe not. Lets hope we never have to find out.
That said, how the hell did anybody ever survive before all of this safety equipment we have nowadays? I remember when cars and trucks only had lap belts! And we're still here!
