Back in the game. RCSB 1500 D-max swap coming...
#94
A floater axle offers versatility along with added strength. If the axle shaft breaks on a floater, The vehicle can still be moved on all 4 wheels. So if your hauling a heavy trailer you can un-hook it and pull the vehicle forward. The axle is bolted to the drive hub. You just pull it out and replace it. Would also be a good Idea to open the housing and clean it out prior to replacing the gear oil.
If a c-clip axle breaks, you need to support the broken side with jack to pull it out from under a trailer. Then you need to hope it didn't tear up the housing or rip the brakes off the end of the housing. A C-clip is held in with a C clip and depending on were the axle snaps, (Usually at the outer bearing end...) it can damage the housing on the way out along with ripping the brakes off the end as the axle comes out and the wheel pulls away.
Hope that shines a little light on the subject.
#97
If the Aussie's can stuff a Duramax/Allison into a Nissan Patrol, I think a Silverado 1500 should be no problem. Looks like they use the rest of the stock drivetrain too FWIW.
Nissan Patrol Duramax - Duramax Diesels Forum
Pretty clean install too. And I like that he off-roads it AND drag races it!
#98
#100
High on diesel fumes
