96 RCSB LS Swap
Old 01-26-2015, 12:22 AM
Ratfinkracing's Avatar
Default 96 RCSB LS Swap
Just recently acquired this truck and realized I haven't done anything fun in many years nor have I had the desire to build anything because of other hobbies. All that has changed and I'm going to focus on building a LS powered 96. Truck is fairly clean some things will stay some won't. So let's get to the questions. I'm purchasing a 99 ECSB with a 4.8, im going to use what I need and sell the rest. I don't plan on keeping the 4.8 forever but for now it will work. My question is what needs to stay and what needs to go. I've seen and read on builds here and there and a lots been said and some of which needs to be clarified. Should I swap engine/trans or keep the current 96 4l60? I don't mind piles of wiring and making change. I just need to know what's best for future upgrades. I plan on a 6.0 and 80 later on.
Old 01-26-2015, 01:16 AM
the hoops are the first thing to get thrown out lol
Old 01-26-2015, 02:55 PM
thunderwagen's Avatar
Use the trans that comes with the 4.8 and if you can swing it I would just sell both 60e's and the motor out of the 96 and get a 4l80 from the get go. That way you aren't redoing stuff down the road. But I guess it depends on how much power you are planning to make and how hard you plan on being on the truck.
Trick does have a hot parts kit for these body style trucks with LS swaps. He used mine for mockup.
Old 01-26-2015, 07:40 PM
Gotcha, well today I bought a 6.0 cheap and I may just sell the 4.8 dirt cheap so I can get a better head start . I can make the 60 work I have no problem building it to suit my needs. I wanted an 80 from the start but if I can't find one i can't use one lol.
Old 01-27-2015, 12:29 PM
SCOTT_A's Avatar
Truck looks like a good place to start.
Old 01-28-2015, 08:19 AM
It's in pretty good shape, the suspension is going to get some work lol.
Old 01-31-2015, 01:41 PM
What mounts and headers are guys using for this body style ?
Old 01-31-2015, 02:08 PM
BigBlock90's Avatar
i used these mounts for my truck. bolt these on the LS motor and then bolt the 3-bolt cup from the old motor on to these and set it in.
http://www.summitracing.com/parts/trd-4572/overview/
Old 01-31-2015, 03:40 PM
SCOTT_A's Avatar
I used conversion mounts from Dirty Dingo with the factory rubber mounts. Headers are from Schoenfeld and are specific for LS swaps in the 88-98 2wd trucks. The fit is very good.
Old 02-02-2015, 03:15 PM
I used the transdapt mounts on mine too. You will have to either grind down or cut out the little raised up triangular section on the cups so they fit flush with the adapter plates.
Bluecollar Hotrods
03-13-2017 05:02 PM
OHsixLS3
12-27-2016 09:30 AM
greedygenius
09-03-2015 06:51 AM
creekrat
08-02-2015 01:27 AM
Quick Reply: 96 RCSB LS Swap
