'89 Chevy C1500 5.3 turbo build
Old Sep 25, 2012 | 10:34 AM
  #101
LS1FREEK's Avatar
13 Second Truck Club
Originally Posted by TRD_Tundra
Question... Finally got to installing my turbo kit, I see that the fitting is in the way of the bolt, did you just leave the bolt off?
Originally Posted by vicalma03
Im sure he drilled and tapped the oil pan for that an fitting. That way you can bolt the pan to the block and then screw the fitting in.
I did drill and tap the oil pan but I actually first put the bolt in the pan, put the fitting in, then put the pan on the block bolting that bolt up first with a wrench.
Old Sep 25, 2012 | 10:43 AM
  #102
LS1FREEK's Avatar
Truck is running very strong!!! Im on about 8-10psi with E85! I can't believe the little 255 flows that much lol. I'll have some speedo bids up as soon as I get the speedometer working. I ran my brothers truck (Jake99- Turbo 4.8), I was on 5psi and he on 13psi and we were dead even from a 40 roll to 100 ;D
Old Sep 25, 2012 | 03:18 PM
  #103
black00chev's Avatar
Slowest turbo build ever!
Awesome to hear man! Just keep a close eye on your fuel pressure.
Old Sep 30, 2012 | 07:11 AM
  #104
Ls7teroy's Avatar
Registered User
Cool project man! I have a 89 myself with a lt1 right now and a 6-speed however i just got ahold of a ls7 so before long i hope to be starting the install.
Old Oct 5, 2012 | 09:03 AM
  #105
LS1FREEK's Avatar
Well I was having problems burning up my plug wires so I did this! Cheesy, I know but very effective! I bought a roll of new wires and just use the ends off of my burned up wires to make slightly longer ones. Plate is aluminum wrapped with header wrap.
Old Oct 5, 2012 | 02:39 PM
  #106
SuperStepside's Avatar
Looks good. Intake setup is next? Also harbor freight needle nose pliers ftw.
Old Oct 8, 2012 | 06:43 AM
  #107
LS1FREEK's Avatar
Finished product pics!!! (although the intake is temporary lol)
Also got some track times!!! I'm not to concerned about the time because its still on the stock converter. This was 3400ft D/A, 4200# race weight and on 11psi.
Old Oct 8, 2012 | 12:31 PM
  #108
WhiteChevy3's Avatar
Nice build bro!
I assume u are running untouched stock 317 heads?
Old Oct 8, 2012 | 12:47 PM
  #109
oakley6575's Avatar
That is a good MPH. Lets see some driving vids!
Old Oct 8, 2012 | 12:53 PM
  #110
damn that 122mph trap speed is nice!
