6.0 Turbo build
Old Feb 28, 2014 | 06:26 PM
  #71
GMCtrk's Avatar
Just so you know, Russel makes bolt on AN fittings for the stock fuel rail quick connects.
Old Feb 28, 2014 | 06:39 PM
  #72
stroker87's Avatar
really? by chance have the part number?
Old Feb 28, 2014 | 06:41 PM
  #73
GMCtrk's Avatar
Just search Russel specialty EFI fittings on google.
I wouldn't want any compression fittings on my fuel lines. Too risky if one lets go. The russel fitting actually is secured by a screw on to prevent it from popping off.
Old Feb 28, 2014 | 06:57 PM
  #74
stroker87's Avatar
Thanks man this is just the info I needed!
as for the compression fittings long as there installed correct he should be ok and since his dad uses them all the time i think he's all good.......
Old Feb 28, 2014 | 07:17 PM
  #75
03sierraslt's Avatar
I have used those compression fittings that he has, they are the real deal. As for the fuel lines I would prefer the Russel setup but those fittings are a double lock and work great.
Old Feb 28, 2014 | 11:47 PM
  #76
GRRR65GTO's Avatar
Got the regulator in and fired up the truck and no leaks, well fuel leaks anyways....
Now the an adapters screwed into the radiator are leaking so i guess ill have to chase down that problem now....
Old Mar 1, 2014 | 05:01 PM
  #77
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
how do you have your crankcase breather hooked up I'm guessing to both valve covers
Old Mar 1, 2014 | 08:08 PM
  #78
GRRR65GTO's Avatar
Yup, the passenger side actually uses the stock hose from the valve cover to the TB and for the drivers side I drilled out the hole in the PCV valve thing so its not tiny any more and ran 3/8 hose to the can. I'd think that should be plenty. I you wanted to you can run a hose from the top of the can to your supercharger inlet so you dont get a smell, I know turbo guys do that but I dont know about procharger guys
Old Mar 2, 2014 | 12:44 PM
  #79
blownescalade62's Avatar
You need a monster catch can like this!
Old Mar 2, 2014 | 05:46 PM
  #80
stroker87's Avatar
can you tell me why thats need? I'm going to be installing a turbo pretty soon and still trying to get parts together and figure out whats needed and how its installed......
