6.0 Turbo build
#73
Just search Russel specialty EFI fittings on google.
I wouldn't want any compression fittings on my fuel lines. Too risky if one lets go. The russel fitting actually is secured by a screw on to prevent it from popping off.
#74
Thanks man this is just the info I needed!
as for the compression fittings long as there installed correct he should be ok and since his dad uses them all the time i think he's all good.......
#76
Got the regulator in and fired up the truck and no leaks, well fuel leaks anyways....
Now the an adapters screwed into the radiator are leaking so i guess ill have to chase down that problem now....
#78
Yup, the passenger side actually uses the stock hose from the valve cover to the TB and for the drivers side I drilled out the hole in the PCV valve thing so its not tiny any more and ran 3/8 hose to the can. I'd think that should be plenty. I you wanted to you can run a hose from the top of the can to your supercharger inlet so you dont get a smell, I know turbo guys do that but I dont know about procharger guys
#80
