2008 yukon build.....Err uh mod thread
Old Jun 19, 2016 | 06:11 PM
  #231
Wolftrk99's Avatar
Dug around and found wiring diagrams for an 08 denali and my yukon, being an SLT about the only options my truck doesnt have are the 6.2/6L80 and the denali appearance package as far as i can tell from wiring and RPO codes anyway. I also verified that all the wires are there for the tu/td shifter in the column and at the bcm.... Already verified part numbers on bcm are same in mine as an 08 denali that was in the shop at work a couple weeks ago, only thing i still need to check at this point is the cluster part numbers....have shifter ordered already should be in monday.... Now just a matter of getting engine and trans together and in.... As far as i can tell at this point theres no reason a reflash wouldnt work to get everything including tu/td working.... Just baffles me that gm didnt go ahead and out the 6l80 in the nnbs suvs at least with the body change....
Old Jun 20, 2016 | 05:30 PM
  #232
Wolftrk99's Avatar
Transfer case adaptor for the 6l80 came in today.... Also got my shifter this morning but left it in my toolbox at work.....
Old Jun 26, 2016 | 12:44 PM
  #233
Wolftrk99's Avatar
Did some more digging, found out my yukon has same os installed as an 08 denali with 6l80 in the repository on hptuners!!! Ready to get rolling on this.....
Old Jun 26, 2016 | 12:49 PM
  #234
About20ninj45's Avatar
Hello yea. In for updates
Old Jun 28, 2016 | 09:56 AM
  #235
Wolftrk99's Avatar
Hopefully i will be able to tear the 6l80 down this evening and see what all it needs, aside from the usual suspects(pump, 1-2-3-4/3-5-r drum and i suspect burnt 4-5-6/2-6 clutches) so long as i dont need a rear planetary i should be able to get it back together for a lot less than i realized. I am,for the moment anyway, planning on GM frictions and steels, sonnax zip kit and probably the sonnax 4-5-6 piston and 1-2-3-4 piston, and possibly the sonnax pump spring.
Old Jun 28, 2016 | 06:35 PM
  #236
Wolftrk99's Avatar
6l80 was pretty bad, but i have seen a lot worse, it had the old style pump in it that tended to lose pressure due to the seals rolling on themselves, already sort if planned on it having the older pump... Already had an ls bellhousing and pump cover, as well as a newer 3-5-R drum(more on that in a bit).
Valve body/tcm removed.... Screwed me up for a minute it had 10mm head bolts where the 10epc torx were supposed to be....
Trash in pan....
Vette bellhousing/pump ready to come off
Pump face not too bad... Looks worse than it was...
The bellhousing side was worse than the pic shows.....
1-2-3-4 clutches burnt fairly well....
3-5-r was TOAST!!!!! Hardly any material left on the frictions.... Could see the crack in the drum, no air check needed!!!
Slight bowing of the 3-5-r clutches!!!
Old Jun 28, 2016 | 06:46 PM
  #237
Wolftrk99's Avatar
Think these are 4-5-6 clutches...
Snap ring from hell!!!!
Center support which is also the 2-6 and low/reverse clutch housing...
The output planetary assembly
Output ring gear... All teeth intact!!
Old Jun 28, 2016 | 06:55 PM
  #238
Wolftrk99's Avatar
4-5-6 hub came apart and the splines are chewed up from the stripped 4-5-6 clutches
More of the 4-5-6 clutches
2-6 clutches dont look too bad
Likewise with the low/reverse
No chewed up teeth on the planetary
Everything going back in temporarily without clutches and an output shaft
Center support back in
Went ahead and set the new 3-5-r in with the clutches.... The vise grips are the 1-2-3-4/3-5-r instalation band tool!!
Ls bellhousing in place
Valve body mounting....
Old Jun 28, 2016 | 07:52 PM
  #239
Wolftrk99's Avatar
Planning to pull the valve body/tcm apart, probably later in the week, to check the valve and see if any of the membranes on the tcm are damaged or not
Old Jun 28, 2016 | 11:57 PM
  #240
89sierra's Avatar
its funny i can see 3-4 different parts of thats transmission we make lol
