2001 Frame up build
Old Apr 6, 2008 | 10:30 PM
  #331
front suspension geometry, I'd like to keep the factory geometry at my ride height that way my roll center and such is still set correctly so it will handle like a mean machine. Plus I was going to back half the other frame if I kept it to run wider rims, 20x15 so I figured I'd go all out.
Old Apr 6, 2008 | 10:38 PM
  #332
ZR1 DREAMING's Avatar
20x15? Dayum... is that for sure the size you plan on running?
Old Apr 6, 2008 | 10:43 PM
  #333
yea that's my plan with 7.5" BS I know I could run more but that's what I want to run. I plan to run the MT sportsman tires on them the 29" tall ones. Thats a huge purchase and won't be for a couple months, but I got enough to work on till then.
Old Apr 7, 2008 | 01:32 PM
  #334
That's some nice rubber
Old Apr 12, 2008 | 09:58 PM
  #335
joehawkz71's Avatar
any more updates man?
Old Apr 23, 2008 | 03:49 PM
  #336
joehawkz71's Avatar
Ttt......
Old Apr 23, 2008 | 04:16 PM
  #337
sorry man, no updates, besides head work... I don't have the cash right now to get some of the things I need to tie this frame together.
Old May 11, 2008 | 09:40 PM
  #338
So a month has been gone by and I have been working on it here and there, been a little buys but got a decent amount done.
So I needed to make the rear of the frame mate with the front, I did an overlap design and bent them inwards to produce the design
Marked them
Cut them
Beveled the edges for good penetration
Then welded them up
Marked and cut the angles, clamped them up
All hidden gussets
Veiw from above
Tight area to get welded
Now since the gussets plug welds, and seam weld are inside that tight area I ground them smooth before I welded the two sides
Also my rear frame height I wanted to alter, to a lower height
Did the same thing, hidden gussets
Ground smooth
  #339
Next day started the next side and squaring everything up
Here is how I did the gussets
Marked them out
My second set of hands while I drilled
Drilled
Did this to all of the parts for that side at once
Needed to make some gussets, everything is 3/16"
Plug welded, edges beveled 45*
Slide them together tacked the corners and clamped the **** out of them
All plugged
Pulled the rail down and laid it flat and clamped it tight, welded the seam
Let it cool, ground it smooth
Back up and done for the weekend
Old May 11, 2008 | 09:41 PM
  #340
It's getting there, next weekend it will all be one piece, need to get a set of 2" Drop spindles asap so I can do my front suspension and order my brackets for that.
