2000 silverado rclb to rcsb drag truck low budget conversion
Old May 26, 2012 | 12:44 AM
  #291
ccreddell's Avatar
It's not like he is trying to build a TB out of schd 80 pipe, or taking the brakes off for weight reduction.
Dont give him any ideas.....
Old May 26, 2012 | 01:16 AM
  #292
Spoolin's Avatar
GFYS and STFU
Originally Posted by UeVmy5.3
taking brakes of is a lot of weight that can be removed lol just kidding really don't do that
Well... if you guys look around you'll notice that there's a member on here who's done both those things (hence the reference ccreddell), and now goes around and gives people advice on builds like he knows what the hell he's talking about.
I agree with Mangled, I think this kids got ***** and good idea's but no experience.
Old May 27, 2012 | 12:19 AM
  #293
CAGRacing's Avatar
Let's not go bashing other members here. There's a lot worse than mine floating around, but that's neither here nor there.
I'm just documenting what I'm doing.
Old May 27, 2012 | 12:57 AM
  #294
chevyrida's Avatar
Registered User
Thumbs up
2000 silverado rclb to rcsb drag truck low budget conversion-052612135834.jpg
i put on the ss bumper n the 24s
Old May 27, 2012 | 04:45 AM
  #295
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by CAGRacing
The frame is cut at an angle to maximize welding surface area. If you look at the frame rail below where the tubing is attached you'll see a line where my weld penetrated.
The tubing is welded wherever possible to the original frame. The upper joint is gusseted but I was really limited as the angle of the joint is only 15 degrees.
I have been thinking this over and as far as your suspension design goes I think the angle of your trailing arms are going to cause an issue with the coil springs and your U joint.
As the spring compresses under force the angle of the arm is going to pull the axle up and forward. Doing this is going to pull the spring forward essentially trying to rip it out of its pocket. In addition to that your pinion is going to rotate downward increasing the pinion angle in relation to the drive shaft angle and putting more stress on the U joint.
What you want is for the pinion to maintain as close to a zero angle difference with the drive shaft as possible through out it's suspension cycle. You may want to consider moving them under the axle to put them more parallel with the drive shaft and minimize any pull/push forces on the coil springs. A good example would be to look at the way they set up a NASCAR chassis rear suspension. I am not saying you have to use Long Truck arms but look at how there set up functions.
I have exaggerated a drawing of what I currently see. Keep in mind that all your mounting points are solid as you move the suspension through its arc.
Attached Thumbnails 2000 silverado rclb to rcsb drag truck low budget conversion-rendering-issue.jpg
Old May 30, 2012 | 09:22 AM
  #296
CAGRacing's Avatar
Went shopping last night
39" Dana 60
42.25" 9"
Ladder bars WITH panhard bar
Old May 30, 2012 | 11:21 AM
  #297
silver-mod-o's Avatar
Hunt&Fisherator
Niff, charge your phone up
Old Jun 26, 2012 | 11:54 PM
  #298
1FastBrick's Avatar
Have you made any progress lately with any of the new parts???
Old Jun 27, 2012 | 01:55 PM
  #299
2 tone 02's Avatar
I was hoping this was an update!
Old Jun 27, 2012 | 02:02 PM
  #300
CAGRacing's Avatar
