2000 silverado rclb to rcsb drag truck low budget conversion
Old Apr 25, 2012 | 10:44 AM
  #101
Tuckin15s's Avatar
Lol I'm sure that link is gonna plant 1000 to the ground without a problem.....
Old Apr 25, 2012 | 11:35 AM
  #102
BlackGMC's Avatar
Resident Retard
Since i dont see a welder in any of the pictures. I bet that 2 bar setup is either gonna shear the bolt it is riding on or break the bar were you drilled it. You should have a sleeve welded in the hole in the bar so all that force is not riding/pivoting on the 1/8 inch contact area where the bolt touches the bar.
Old Apr 25, 2012 | 11:44 AM
  #103
f4tal's Avatar
Make sure you test drive it before you race it. Preferably at 2:30 in the morning... in Pennsylvania... racing a Porsche 911... drunk...
Too soon?! R.I.P. Dunn
Old Apr 25, 2012 | 12:04 PM
  #104
CAGRacing's Avatar
That bar is 3/8" thick cold rolled round edge oval tube
36" is good for around 6,000 lbs lateral force
the pivot point will be getting a piece of angle iron to attach it further to the frame then a seam weld.
If it breaks it wasn't meant to be and I won't be too concerned with it.
Old Apr 25, 2012 | 12:06 PM
  #105
CAGRacing's Avatar
Oh and the bolt is grade 8 9/16" diameter. Good for 14,000 lbs of shear or something stupid high.
Old Apr 25, 2012 | 12:53 PM
  #106
SCOTT_A's Avatar
The 9/16" bolt isn't what I would be first concerned with... its the front spring mount, and the manner its fixed to the frame. It needs a lot of support being so far from the frame. And it looks like its held in place with 3, 3/8" bolts... You can run all the engineering numbers you want, but it doesn't look safe to me. In the picture, you can see where you cut the spring mount from its original location and from the factory it is much more supported than you have it in its new location.
Not trying to bash you dude, I appreciate going fast on a budget... but safely.
Old Apr 25, 2012 | 01:49 PM
  #107
TXsilverado's Avatar
1,000 budget HP FTW!
Old Apr 25, 2012 | 03:01 PM
  #108
Beau@SDPC's Avatar
Trucks Sponsor
SUBSCRIBED! Interested to see the finished product. Good Luck!!! Keep the updates/pictures coming!
Old Apr 25, 2012 | 03:28 PM
  #109
BlackGMC's Avatar
Resident Retard
honestly i think you missed the point of my post... The tubing and the bolt may be good for 1million lbs, however the way you have it setup will act like a saw without a sleeve welded to the inside of that tube for the bolt to contact... right now the wall of the tube is resting right on the bolt so every time the tube pivots it is rocking back and forth, basically creating a saw effect where the tube wall contacts the bolt....
Old Apr 25, 2012 | 03:54 PM
  #110
CAGRacing's Avatar
That's where I'm putting angle iron and seam welding. But I'm looking at switching axles for a 14 bolt c&c axle so I'd have to move it all anyways.
