2000 silverado rclb to rcsb drag truck low budget conversion
Old May 9, 2012 | 08:30 PM
  #201
BlackGMC's Avatar
Resident Retard
Just a peice of advice about your notch. You should have used a longer piece if angle iron. It appears you used just enough to cover the opening you cut. You should have extended it about a foot on each side to spread the load over a larger area. Take a look at off the shelf notches they are really long. So with that said i would cut off that piece you used and install one 3x as long.
Also looking at the way you attached the spring at the bottom. It appears you used a bolt and a thin piece of metal to "strap" it down. This does not appear to be a good idea either. I sugget looking at some normal coil spring setups and replicate what you see.
Also quite being so cheap, spend the money you need to spend. If you dont have alot of money the accept that your gonna have to work slower to do it right
Old May 9, 2012 | 08:31 PM
  #202
CC05's Avatar
If you can't afford to do it right, how can you afford to do it twice?
Man, that's so appropriate right now.
Old May 9, 2012 | 09:13 PM
  #203
DarkCharisma's Avatar
I don't always post on PT.net, but when I do, it's to wonder what the hell people are thinking when they make "builds" like this.
Old May 9, 2012 | 09:35 PM
  #204
ak2007r6's Avatar
Most of us have learned this early on.. takes some others a little bit longer
Old May 9, 2012 | 09:36 PM
  #205
CC05's Avatar
...if they make it to the age where they learn.
Old May 9, 2012 | 10:05 PM
  #206
BlackGMC's Avatar
Resident Retard
Also another piece of advice, please STOP posting your contact number.... Members can post up links to non-sponsors as long as it is not for personal gain. Usually these types of links are simply deleted however this time, since i am having a boring night, i decided to replace each picture you posted with your number with a different picture.... You can simply blur out or block out your number on future and existing pictures if you want... Please consider this a warning to stop posting your number, besides i believe you mentioned earlier that you were receiving alot of prank calls, this should help solve that...
Thanks and keep up the good work just don't post your number...
Old May 9, 2012 | 10:37 PM
  #207
slammedsilvy's Avatar
LMAO at the cat pictures. I revisited every page of this thread to admire them all.
Old May 9, 2012 | 10:51 PM
  #208
AKlowriderZ71's Avatar
11 Second Hall Moniter
I have to admit, I did the same thing.
Old May 10, 2012 | 09:33 AM
  #209
aaronmc's Avatar
at the cat pics.
Old May 10, 2012 | 09:55 AM
  #210
nonnieselman's Avatar
More Cat Pictures!!!
