03 Sierra Prostreet Paperweight
Old Jan 27, 2020 | 05:53 PM
  #111
xxch0dyxx's Avatar
Originally Posted by Bgbldodge
I do that with a lot of press on parts. Put one part in the oven and the other in the freezer. Makes life very easy.
Double post
Old Jan 27, 2020 | 06:08 PM
  #112
stroker87's Avatar
he dont freeze any thing just heats the bearings up so maybe you can get that pulley back on that way if not easy some light taps with a dead blow while its hot out of the oven? if it works beats pulling the pump off
Old Feb 8, 2020 | 12:26 PM
  #113
xxch0dyxx's Avatar
As I was trying to decide how to attached this PS pulley situation, I ran across a deal...
7675 CEA Precision snail
Turbosmart gate to atmosphere
Custom Bell IC
Have new PS pump in shop to swap out and hopefully finish the truck. Likely to update tune and leave it be for awhile while I work on the above.
Old Feb 8, 2020 | 01:11 PM
  #114
tjmath's Avatar
That looks like a really clean install. Definitely looks like a sleeper. Sure it doesn't sound so sleepy tho.
Old Feb 8, 2020 | 02:48 PM
  #115
stroker87's Avatar
isnt that a hard left turn lol
looks like a fun car
Old Feb 9, 2020 | 01:19 PM
  #116
xxch0dyxx's Avatar
Story of my life... Lol
While I have pump off, decided to take accessory bracket off and clean up a bit. Might rattle can it, or possibly powder coat, haven't decided.
IW 973 tensioner pulley doesn't fit stock truck tensioner, it hits the back on tensioner. Anyone with IW 8 rib have this issue? I have the LC32 sitting on shelf, but wanted to try the IW first since I already paid for it...
Just need to get hub off old PS pump and onto new, then I'll button up.
Old Feb 11, 2020 | 05:28 AM
  #117
ILuvJDM's Avatar
That camaro looks fun, and the truck is looking good.
If you powdercoat or paint the accessory bracket, just make sure you keep all the mounting bosses for the alternator bare aluminum, or you will have charging issues... That goes for the actual mounts for the bracket to the block/head as well on the backside of the bracket.
Old Feb 11, 2020 | 09:54 AM
  #118
xxch0dyxx's Avatar
Well, had to cut the shaft off old pump to get the hub off and use hydraulic press to get out.
Now that that's done, I just have to get hub onto new PS pump and reinstall... Hopefully this time goes a little better.
While I was at it, I pulled accessory bracket off to degrease and paint. Decided painting was a bad idea, so I'll just throw on now that it's cleaned a bit.
Bracket off.
Old Feb 11, 2020 | 04:30 PM
  #119
terravast4's Avatar
Looks nice and clean
Old Feb 11, 2020 | 10:05 PM
  #120
xxch0dyxx's Avatar
Put pump in the fridge for a few hours and hub in air fryer for 20 min on 300*. Hub went on without a hitch.
Moral of story, buy a got install tool instead of using rental...
Will get pump and bracket installed tomorrow and bleed system Thursday after I install LC32 HD tensioner. Still need to find correct 8 rib belt as well.
Hub seated on new pump
