03 Sierra Prostreet Paperweight
Old Jan 11, 2020 | 01:04 PM
  #91
xxch0dyxx's Avatar
Originally Posted by stroker87
i like the seats a lot i think the while really looks good on them
whats the truck hitting the scales at? im thinking you should be well into the 11's @ 500rwhp
It's going to hit... Heavy AF. With the blower, 80e, 9in, and meats on rear, it's a tank. Feels like itll get in 11s pretty easy.
Hope to get the rest of my fittings this week to get fuel back in and FPR in bay. Holding off on my 102mm and 5in intake until I hear back from Jokerz for my port work. Haven't gotten a response from them in 3 weeks since I requested invoice to send blower in.
Still debating console options... Or just slap a 15lb bottle right there to look pretty
Old Jan 20, 2020 | 06:06 PM
  #92
xxch0dyxx's Avatar
Question for the crowd...
Been going back and forth with porting entire blower, or just opening TB and milling snout. Jokerz finally sent me invoice after I settle on snout, so I'm back to debating.
That being said, this snout is SEALED to the case. I tried everything to get it off. At this point, I'm debating doing the blower just to avoid trying to get the snout off again.
Thoughts? I have 2.55" pulley that will be going on after either : - 0
Old Jan 21, 2020 | 07:58 AM
  #93
terravast4's Avatar
I have read that the LSA guys get good results from porting the entire blower. I am sure it cant hurt for airflow. What is the cost for the entire blower?
Old Jan 21, 2020 | 06:12 PM
  #94
xxch0dyxx's Avatar
Will cost about $950 all said and done with shipping.
$350 to open snout.
Old Jan 22, 2020 | 03:00 PM
  #95
stroker87's Avatar
will that pulley push the blower passed its efficiency?
reason im asking is my cousin has upper and lower pulleys on his GT500 mustang and after a pull or two on the highway the car is heat soaked really bad,,,
Old Jan 23, 2020 | 08:48 AM
  #96
terravast4's Avatar
That 2.55 is gonna spin that blower out of the efficiency range.
Old Jan 24, 2020 | 07:39 AM
  #97
xxch0dyxx's Avatar
Then what pulley won't? I've seen 2.6" used with a 10% OD crank without issues. I can get any pulley cheap now that I can quick swap. The 2.9 is getting me 9.5psi with my setup.
Old Jan 24, 2020 | 08:27 AM
  #98
terravast4's Avatar
How hard you gonna push it? 2.55 pulley with 10% overdrive shifting at 6800 rmp puts the blower in the 22k range, shifting at 6200 puts you in the 20k range which is said to be max rpm’s before efficiency falls off.
Old Jan 24, 2020 | 10:27 AM
  #99
xxch0dyxx's Avatar
With the 1219 springs and cam I have, i have it shifting at 6200 and dont really plan to wind it out anymore than that. Cam wasnt made to make power in the upper 6k range.
Also dont go out doing hot laps, just pulls here and there with occasional trip to track and gapplebees.
Old Jan 24, 2020 | 12:22 PM
  #100
terravast4's Avatar
I have heard a mix of info on this and I know every set-up is different. Some say they make power spinning the blower to 22k and some say once you get past 20k the power falls off fast. I think a big part is how efficiently you are getting air in and getting air out. I think if you have pre-blower restrictions like small intake tube and small throttle body the blower is already working harder to get the air in.
