Welp it happened - 427ci lq9 ate it
Old May 22, 2017 | 10:52 AM
  #81
Vortec350ss's Avatar
Originally Posted by Blown06
Hold up. Now you're telling us you don't really know anything about the history of that thing. Piece of **** was probably a 200k mile pullout, hit with a flexhone for 45 minutes on each hole, add 4" crank, run the **** out of it........whoops, that 4" **** don't work.
Let's not jump to conclusions here. Thats not even remotely true. It's a low mile motor.
Old May 22, 2017 | 11:07 AM
  #82
arthursc2's Avatar
Well.
This is disheartening.
Old May 24, 2017 | 01:23 PM
  #83
Ken in AZ's Avatar
Heads come off this weekend - need some advice....
Should I send them off to WCCH for their Stage 3 L92 CNC program or is their another head you recommend?
thanks!
Old May 24, 2017 | 02:11 PM
  #84
WCCH does good work. I wouldnt shy away from them.
Old May 24, 2017 | 03:05 PM
  #85
fctry286's Avatar
I just had my Heads done by WCCH top notch. I couldn't tell you what they did my buddy knows the machinist and told him what I was running and gave it his "special" treatment. lol
Old May 24, 2017 | 03:39 PM
  #86
oakley6575's Avatar
I've always wanted them to a set of my heads.
Old May 26, 2017 | 09:20 PM
  #87
Ken in AZ's Avatar
Just ordered a set of those new id1050x's injectors. Sick of the deka 80lb'ers.
Heads come off tomorrow and will be going to WCCHfor their stg 3 program. I'll probably put my old cam back in and order a set of the PAC-1205 or 1206 springs with titanium retainers to handle the .660" lift that cam has.
Praying there's no bearing damage - haha
I actually drove the truck a little today just to see what the oil pressure was looking like and to get it hot and check the oil level. Pressure was steady everywhere and the oil looked good and full so that's a good sign for bearings.
I need to save $$ for lifters just in case too - what's a good/better lifter than the LS7 from GM?
Old May 26, 2017 | 11:58 PM
  #88
zero2sixT's Avatar
Im about to run Johnson 2110 slr. GM used them in the copo Camaro 427
Old May 28, 2017 | 06:48 PM
  #89
darkirish63's Avatar
Using these in my current Stroker build. Going to crank it up tomorrow. I've lost an LS7 lifter twice so the extra $ is worth the piece of mind.
Old May 29, 2017 | 08:15 PM
  #90
gammey4's Avatar
I switched from deka 80's to id1050x's, huge improvement.
