Welp it happened - 427ci lq9 ate it
#112
It lives! New Jesel's cause a little bit of a problem and were catching on the edge of the valve cover making a terrible noise like something was bouncing around in a cylinder.
Took them off and clearanced them and reset valve preload and boom, it lives again!
#113
Just an update - seems to be running better than ever. Oil looks good, no weird noises. I'd say I dodged a bullet.
I've put two tanks of fuel through it so far. The only issue I had was the AC wasn't working well on the freeway. $2.29 orifice tube and some fresh refrigerant and it's ice cold again.
Fuel trims are a little off, but that's from switching from the Deka 80's to the ID1050's. WOT it get's close to hitting the AF targets but it needs to be dialed in a bit more. Goes back on the dyno on June 2nd to get the treatment from NicD.
Keep you posted.
Keep you posted.
#114
Keep you posted.
Keep you posted.
#115
I'm putting the 5.13 gears in the 14 bolt as we speak - I buggered up the pinion bearing...at $110 mistake, but setting up the 14 bolt was a breeze....If I knew it was that easy I would have done it a long time ago.
