Welp it happened - 427ci lq9 ate it
Old May 12, 2017 | 10:26 AM
  #41
03sierraslt's Avatar
Originally Posted by Blown06
Hey bud, hope you get it figured out. Remind me again, what is the bore/stroke combination on this engine? Also, what is the rod length?
4.07 bore
4.1 stroke
I really hope this isn't a LQ4/lq9 block with that combo.
Old May 14, 2017 | 01:58 AM
  #42
Blown06's Avatar
8 Second Truck Club
4.07 bore
4.1 stroke
Why would you hope that it isn't an LQ4/LQ9 block???
Old May 14, 2017 | 06:46 AM
  #43
Not much liner left and that really drops the piston out of the skirt on an LQ4 block. Lots of piston rock.
Old May 14, 2017 | 12:16 PM
  #44
Ken in AZ's Avatar
6.125
4.070
Old May 14, 2017 | 04:01 PM
  #45
Gadgetized's Avatar
Did you swap injectors around to see if the problem followed?
Old May 15, 2017 | 12:04 AM
  #46
Blown06's Avatar
8 Second Truck Club
4.07 bore
4.1 stroke
All the more reason I'd like to see this dude succeed....LQ life isn't for everyone lol
Old May 15, 2017 | 12:08 AM
  #47
Blown06's Avatar
8 Second Truck Club
I'd like to question...has anyone seen how extremely short you can get the skirts on a custom piston? I'd like to see that with an even shorter rod to help the top of the piston out some. 6.125" rod on a 4.100" arm only yields a compression height of about 1.065" compression height on a really fresh and tall 9.240" block.
Old May 15, 2017 | 08:24 AM
  #48
MikeGyver's Avatar
You are getting out of the street driven vehicle area with that stuff. Shorter pistons that are more prone to rocking and shorter rods that put even more thrust on the face of the pistons are for the 1/4 mile crowd only. Or anyone else who is going to rebuild their engine fairly often.
Old May 15, 2017 | 02:07 PM
  #49
Ken in AZ's Avatar
Well I've decided to pull the heads and send them to wcch for their stg 3 program.
I'll pull the lifters and inspect as well as pull the cam - if I see bearing wear I'll likely pull the engine for a refresh or a new block. Depending on what I see will determine next steps but I'm really hoping for minimal wear and just a new cam and lifters so the build can "live" haha
Old May 15, 2017 | 08:30 PM
  #50
terravast4's Avatar
good luck!!
